Thread: Smoke coming from engine
Results 1 to 20 of 21
  1. #1 Smoke coming from engine
    Sep 2017
    Texas
    I have had my car sitting since May due to working out of town, but when I went to go start it today it had a hard start and smoke coming from rear of the engine. At first I thought valve seals but from what I have read is that will make blue smoke so now I'm not sure. I'll be doing the Lim, water pump, valve cover seals, and a shift kit here soon on the car just wondering if I need to add more to the list.
  2. #2 Re: Smoke coming from engine
    rear vc oil leak. if we're talking engine bay smoke. not tail pipe.
  3. #3 Re: Smoke coming from engine
    Sep 2017
    Texas
    Okay awesome, thank you for your help on this, was definitely nervous it was something worse.
  4. #4 Re: Smoke coming from engine
    Sep 2017
    Texas
    I don't want to start a new thread so another question, should I replace my lifters also since I'm doing the VC gasket and Lim? I also was reading and saw I should also change out my heater core hoses?
  5. #5 Re: Smoke coming from engine
    not unless they are ticking up a storm. im a huge fan of dont fix whats not broken.
    hoses get old, could be factory still. if they are soft or look like crap, change em. my parts store didnt even have em in stock, so make sure what they are giving you is a match.
  6. #6 Re: Smoke coming from engine
    Kemmerer, Wyoming
    you could do LS7 lifters, they are a direct replacement and work good.
  7. #7 Re: Smoke coming from engine
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    New hoses are short money for peace of mind. Both heater hoses AND both rad hoses should run under $100.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  8. #8 Re: Smoke coming from engine
    Sep 2017
    Texas
    For injector orings, all 4 hoses, and the thermostat o ring it's only 50 from rockauto so will swap them out also for peace of mind. And I don't believe my lifters are ticking either so those can stay.
  9. #9 Re: Smoke coming from engine
    on rockauto, buy the magnum lim kit, it comes with o rings for the t stat, under the blower and the injectors. its like 42 bucks too. ive used that kit before, its perfect. make sure you get the metal kit.
  10. #10 Re: Smoke coming from engine
    Sep 2017
    Texas
    I already bought the Lim gasket, I wasn't the brightest and bought it off zzp so I definitely didn't get the best deal. Wish I would have got the one you said, same price even.
  11. #11 Re: Smoke coming from engine
    zzp strikes again, theres nothing they have for sale that cant be bought else where cheaper. other then cams and modding parts.
  12. #12 Re: Smoke coming from engine
    Sep 2017
    Texas
    I am definitely learning that, I will be getting a down pipe from there hopefully around Christmas.
  13. #13 Re: Smoke coming from engine
    May 2008
    Schuyler, NE
    I'm not seeing it. Zzp sells the lim gaskets for $40. Rockauto has them for $44.
  14. #14 Re: Smoke coming from engine
    im not seeing the magnum on ra either, must have sold out, found em on ebay for 51. still a deal Engine Intake Manifold Gasket Set Lower Magnum Gaskets MS18144 MADE IN USA | eBay
  15. #15 Re: Smoke coming from engine
    May 2008
    Schuyler, NE
    Are those the ones with all the casting flash on them?
  16. #16 Re: Smoke coming from engine
    they looked and felt just like a felpro. used felpro years ago for its maint lim job.
    only reason i used the magnum 2 times is cause i installed a ic with ported lim. what came off looked as if i could have reused them. (a year old) but im not gonna be that guy for 42 bucks. i did save them tho. never know what might come at ya in life.
  17. #17 Re: Smoke coming from engine
    When you do the valve cover gaskets make sure you do the grommets at the same time . They are what puts pressure on the seals. Also.. if you bought them from ZZP, enjoy the poor fitment.
  18. #18 Re: Smoke coming from engine
    Sep 2017
    Texas
    I did get the grommets at the same time. Which part from zzp will fit pourly the grommets or valve cover gasket? And should I just buy some new ones?
  19. #19 Re: Smoke coming from engine
    Sep 2017
    Texas
    Nevermind seeing that the grommets are Fel pro, I'm guessing it's the valve cover gasket
  20. #20 Re: Smoke coming from engine
    Yes.. the gasket is made to fit their own valve covers and are pulled tight in the corners. After showing a few people the differences, they went and bought the fel pro gaskets to be much happier. Here's some pics from ZZP gaskets on stock covers.
    Those were about 5 years back, so bear that in mind in case they decided to update their molds (doubtful).
  1. HELP smoke coming from engine
    By SF9777 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2012, 11:56 PM
  2. Light Smoke coming from engine comp, Infrequent
    By PlayingMechanic in forum General Tech Discussion
    Last Post: 02-11-2012, 12:29 PM
  3. S.O.S smoke coming from exhaust...
    By kyleinkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 07:33 PM
  4. Smoke Coming out Of my breaks?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2009, 05:34 AM
  5. smoke coming through the a/c vents
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 08-19-2009, 07:05 PM
