I have a 2004 grand prix gtp compg and I recently replaced the fuel pump and filter after noticing i was running lean at high rpm over 5k I also noticed that in my data log my injector duty cycle was well over 80% and went up to 105%. With the new pump and filter installed I measured fuel pressure and at key on and at idle it was around 60 but when i would rev the engine in park no load the fuel pressure would drop to about 50PSI. I recently just measured a voltage drop of 1 volt on the fuel pump power side of the circuit and replaced the ground wire with 12 gauge wire. Im waiting on some A replay and relay socket to get here so I can rewire the hot side of the fuel pump circuit. My question is would a voltage drop of 1 volt cause the drop in fuel pressure and cause my injector duty cycle to max out at high rpm? I dont know what it could be im hoping re wiring the pump will solve it. I havnt been able to find much information on the l32's and the returnless fuel system for this kind of problem.
Mods
Fenderwell intake
180 stat
Autolite 104 plugs
zzp pcm 1.0
3 inch catless downpipe
