Thread: junkyard valve springs?
Results 1 to 13 of 13
  1. #1 junkyard valve springs?
    Jul 2017
    macomb mi
    hey everyone getting some 1.95 rockers from a fellow user on here.
    by the time I get to installing these I will have over 200k miles on the car so im just going to do the springs I've done them on an over head cam engine so this should be a breeze but wondering if it would be a good Idea to go to a junkyard and get some springs and retainers off of an ls6? is this a lightbulb moment or a cheap and dumb idea. just trying to save money as the rockers aren't cheap alone haha. let me know also any tips before I do the install (mistakes to learn from)? also will be doing the valve seals certain method to get those to seal properly or are they pretty easy? and does the rope in the cylinder method work good? because I wont have access to any air do everything I can at the apartment.
  2. #2 Re: junkyard valve springs?
    id get some new 90 lb springs at min.
  3. Likes Iceman6669 liked this post
  4. #3 Re: junkyard valve springs?
    The Boss Iceman6669's Avatar
    Jun 2011
    Ls6 90# are perfect and fairly cheap.
    2011 F-150 Yote powered
  5. #4 Re: junkyard valve springs?
    May 2008
    Schuyler, NE
    I'm impressed you have ls6's in your junkyard.
    If I were you, I would just order l76 (G8 GT) springs from GM. The last time I did, they were less than $3 a piece.
  6. #5 Re: junkyard valve springs?
    Jul 2017
    macomb mi
    lol that's metro Detroit for ya I normally see an average of 3 by accident probably more of I had them print out a list but are those L76 springs too stiff? just asking because I've heard the 1.95s break easier because they are aluminum. also will the #90s be safe?
  7. #6 Re: junkyard valve springs?
    May 2008
    Schuyler, NE
    L76 springs are 90# as well, but have a smaller ramp rate than ls6 springs. They are perfect for rocker cars imo.
  8. #7 Re: junkyard valve springs?
    For installing seals. Felpro should include a piece that sits over the valve stem in order to ensure the seal doesn't get clipped on the lock lip. Then I would lightly oil the area where the seal goes and use IIRC a 1/4" 10mm deep socket and lightly tap with a rubber mallet to ensure it's seated.
    I have done an install with string/rope and it was not a lot of fun. Finding a buddy with a compressor and then using the air line does make it a lot easier overall.
  9. #8 Re: junkyard valve springs?
    the joy of the harbor freight spring compressor too lol
  10. #9 Re: junkyard valve springs?
    I have a couple different spring compressors.. one is HF. They both work.. just a question of how tight things are on the back with the heater hoses. You could pull the motor forward to gain some room.
  11. #10 Re: junkyard valve springs?
    or you could just pull the engine to install them. so much easier that way.....lol
    junkyard valve springs? Attached Images
  12. #11 Re: junkyard valve springs?
    Please.. don't paint your engine like Scottydoggs did. It still hurts my eyes to see it.
    bumble bee tuna, bumble bee tuna
  13. Dislikes Scottydoggs disliked this post
  14. #12 Re: junkyard valve springs?
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    Do you have to get retainers for the L76 springs? (I guess you have to get retainers for the LS6 springs, so just wasn't sure about these)
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  15. #13 Re: junkyard valve springs?
    May 2008
    Schuyler, NE
    You should get ls style retainers. 3800 retainers are slightly different.
  1. Found
    By BuickGS in forum Wanted To Buy - Parts
    Last Post: 08-09-2017, 11:17 PM
  2. Looking for a set of 125/130# Valve springs
    By BuickGS in forum For Sale - Parts
    Last Post: 08-08-2017, 03:09 PM
  3. aluminium valve covers, 90 lb ls6 valve springs for sale
    By SgtMarshal in forum For Sale - Parts
    Last Post: 09-04-2014, 04:30 PM
  4. LS6 90# Valve Springs - SOLD
    By tms8582 in forum For Sale - Parts
    Last Post: 11-19-2013, 03:02 PM
  5. Valve Springs
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 07:05 PM
