#1
Broken valve guide bosses. WTH?
Hello. I'm working on an L32 and diagnosing blue smoke at start-up after blue LS6 springs and valve stem seals were reportedly recently replaced. I figured a valve stem seal came off but it was much worse. When I looked through the spring, I could see the valve stem seal at the top of the valve but the valve guide boss was attached to it! On three separate valves, they're broken off. Can these be repaired/drilled out to fit brass ones, etc? I'm guessing someone pounded the seals on with a mini sledgehammer and deep well socket.
#2
Re: Broken valve guide bosses. WTH?
08-08-2018
sounds like you need a new head. never heard of this one. the engine all stock still?
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
08-08-2018
When I install seals, I use a rubber mallet and a 1/4" 10mm or 12mm deep socket. Never heard of this either. If you pull the head a machine shop should be able to put new guides in.
08-08-2018
with out a pic, it sounds like the seal and the part the seal is pushed on is busted off. thats a bit more then a new guide lol
#5
08-08-2018
How so.. the seal goes onto the guide and seals.
08-08-2018
he said its snapped off with the seal still on it. thats garbage now is it not?
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#7
08-08-2018
Been too long to remember.. I'm thinking it's valve guide that sticks up..but maybe not? If not.. it's new head
08-08-2018
#9
08-08-2018
You got a pic in chat.. from Scott.
08-08-2018
#11
#12
GXP Level Member
08-10-2018
Wow. Never seen that.
Where are you located at? I have tons of heads sitting on the shelf.
#13
Zip code 89147 in Vegas. Thanks.
#14
08-10-2018
Wow! I've got the same issue with the smoke after rebuilding my engine and my guides were replaced too. I'm wondering if the same thing happened to me.... I'll have to update once I get around to it.
#15
You probably just had a seal come off and not the whole valve guide boss.
#16
08-10-2018
Sirayden
You're probably right. It's the one thing I didn't assemble myself and let the machine shop do. But they did replace the springs and seals so I'll just have to wait and see. Are these seals coming off a common thing? I know the boss breaking is rare.
#17
GXP Level Member
08-10-2018
Sirayden
You're looking at about $120 a head total.
#18
Are they series 3 heads you have? What condition are they in? Thanks
#19
wstefan20
There was a service bulletin about seals coming off. I think it was mainly for the exhaust valve seals.
#20
GXP Level Member
08-11-2018
Sirayden
They should be series 2 I believe. I would have a machine shop deck them and clean them before installing. You would have to put your own rockers on, but they come with valves and springs.
