Thread: Broken valve guide bosses. WTH?
Results 1 to 20 of 22
  1. #1 Broken valve guide bosses. WTH?
    Oct 2014
    United States
    Hello. I'm working on an L32 and diagnosing blue smoke at start-up after blue LS6 springs and valve stem seals were reportedly recently replaced. I figured a valve stem seal came off but it was much worse. When I looked through the spring, I could see the valve stem seal at the top of the valve but the valve guide boss was attached to it! On three separate valves, they're broken off. Can these be repaired/drilled out to fit brass ones, etc? I'm guessing someone pounded the seals on with a mini sledgehammer and deep well socket.
  2. #2 Re: Broken valve guide bosses. WTH?
    sounds like you need a new head. never heard of this one. the engine all stock still?
  3. #3 Re: Broken valve guide bosses. WTH?
    When I install seals, I use a rubber mallet and a 1/4" 10mm or 12mm deep socket. Never heard of this either. If you pull the head a machine shop should be able to put new guides in.
  4. #4 Re: Broken valve guide bosses. WTH?
    with out a pic, it sounds like the seal and the part the seal is pushed on is busted off. thats a bit more then a new guide lol
  5. #5 Re: Broken valve guide bosses. WTH?
    How so.. the seal goes onto the guide and seals.
  6. #6 Re: Broken valve guide bosses. WTH?
    he said its snapped off with the seal still on it. thats garbage now is it not?
  7. Likes ItHurtz liked this post
  8. #7 Re: Broken valve guide bosses. WTH?
    Been too long to remember.. I'm thinking it's valve guide that sticks up..but maybe not? If not.. it's new head
  9. #8 Re: Broken valve guide bosses. WTH?
    Antioch, IL
    in for pic
    2009 Challenger SRT8
    Expert at being gay.
  10. #9 Re: Broken valve guide bosses. WTH?
    You got a pic in chat.. from Scott.
  11. #10 Re: Broken valve guide bosses. WTH?
    Antioch, IL
    ops pics
  12. #11 Re: Broken valve guide bosses. WTH?
    Oct 2014
    United States
    Not good. Anyone have any good, used heads for sale for cheap? I guess series 2 or 3 will work. There are series 3 heads.
    Broken valve guide bosses. WTH? Attached Images
  13. Likes ItHurtz liked this post
  14. #12 Re: Broken valve guide bosses. WTH?
    May 2008
    Schuyler, NE
    Wow. Never seen that.
    Where are you located at? I have tons of heads sitting on the shelf.
  15. #13 Re: Broken valve guide bosses. WTH?
    Oct 2014
    United States
    Zip code 89147 in Vegas. Thanks.
  16. #14 Re: Broken valve guide bosses. WTH?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Wow! I've got the same issue with the smoke after rebuilding my engine and my guides were replaced too. I'm wondering if the same thing happened to me.... I'll have to update once I get around to it.
  17. #15 Re: Broken valve guide bosses. WTH?
    Oct 2014
    United States
    You probably just had a seal come off and not the whole valve guide boss.
  18. #16 Re: Broken valve guide bosses. WTH?
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Sirayden View Post
    You're probably right. It's the one thing I didn't assemble myself and let the machine shop do. But they did replace the springs and seals so I'll just have to wait and see. Are these seals coming off a common thing? I know the boss breaking is rare.
  19. #17 Re: Broken valve guide bosses. WTH?
    May 2008
    Schuyler, NE
    You're looking at about $120 a head total.
  20. #18 Re: Broken valve guide bosses. WTH?
    Oct 2014
    United States
    Are they series 3 heads you have? What condition are they in? Thanks
  21. #19 Re: Broken valve guide bosses. WTH?
    Oct 2014
    United States
    Quote Originally Posted by wstefan20 View Post
    There was a service bulletin about seals coming off. I think it was mainly for the exhaust valve seals.
  22. #20 Re: Broken valve guide bosses. WTH?
    May 2008
    Schuyler, NE
    They should be series 2 I believe. I would have a machine shop deck them and clean them before installing. You would have to put your own rockers on, but they come with valves and springs.
  1. driver side seat belt guide broken
    By Larry N in forum General Tech Discussion
    Last Post: 05-31-2015, 12:05 PM
  2. Fixed broken valve spring, Still misfiring heads are off
    By Kasey in forum General Tech Discussion
    Last Post: 09-19-2011, 08:06 AM
  3. Cylinder 5 misfire UPDATE Broken valve spring
    Last Post: 09-12-2011, 07:32 PM
  4. Bent pushrod and broken valve spring?
    By brokenmercy in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-07-2011, 05:31 PM
  5. Broken Valve Stems
    By ubmarine in forum Tires & Wheels
    Last Post: 02-27-2010, 07:40 PM
