Thread: Broken valve guide bosses. WTH?
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Broken valve guide bosses. WTH?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Sirayden View Post
    There was a service bulletin about seals coming off. I think it was mainly for the exhaust valve seals.
    That would make sense if it was the exhaust. Plugs aren't fouled and no carbon on the intake valves, but great compression and only smokes a tiny bit when idling for long periods.
    Is there any way to prevent this? I used felpro seals.
  2. #22 Re: Broken valve guide bosses. WTH?
    Oct 2014
    United States
    Okay, thanks. I'll get back to you if I decide to buy a pair.
  1. driver side seat belt guide broken
    By Larry N in forum General Tech Discussion
    Last Post: 05-31-2015, 12:05 PM
  2. Fixed broken valve spring, Still misfiring heads are off
    By Kasey in forum General Tech Discussion
    Last Post: 09-19-2011, 08:06 AM
  3. Cylinder 5 misfire UPDATE Broken valve spring
    Last Post: 09-12-2011, 07:32 PM
  4. Bent pushrod and broken valve spring?
    By brokenmercy in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-07-2011, 05:31 PM
  5. Broken Valve Stems
    By ubmarine in forum Tires & Wheels
    Last Post: 02-27-2010, 07:40 PM
