Thread: Stock rocker ratios
Results 1 to 6 of 6
  1. #1 Stock rocker ratios
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    So after some facebook/old forum research, it appears that the 99+ stock rocker is a 1.66 vs the 96-98 being 1.6. I'm not finding a ton of evidence but there is some info here and there. Nothing 100% though. Does anyone here have any info?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Stock rocker ratios
    May 2008
    Schuyler, NE
    I'm not convinced there is any difference. It would be interesting to measure an older rocker vs a newer one to actually see.
  3. #3 Re: Stock rocker ratios
    Apr 2014
    South Haven, MI
    That's kind of where I'm at with it. I have a 98 and I've got a set of 04 rockers in the garage.
  4. #4 Re: Stock rocker ratios
    I highly doubt there is a difference. However it has been noticed that it depends on where you measure. As the rocker tip is pushed down, you are using more of the edge vs the middle and that's where I believe the difference is found.
  5. #5 Re: Stock rocker ratios
    Check the part numbers and see if there was a change.
  6. #6 Re: Stock rocker ratios
    Apr 2014
    South Haven, MI
    I may have a spare set of rockers from a 97 I can compare them to. I'll report back here with my findings
  1. Stock rocker arm bolt source?
    By 2004l67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2015, 09:08 PM
  2. Rocker ratios do not seem correct from differnt manufacturers
    By Frosty in forum General Tech Discussion
    Last Post: 01-19-2014, 02:23 PM
  3. Rocker ratios affect on lift / duration
    By L36 Killer in forum General Tech Discussion
    Last Post: 03-21-2013, 10:30 AM
