Thread: Fuel pump wiring harness
Results 1 to 3 of 3
  1. #1 Fuel pump wiring harness
    Pennsylvania
    I got an ac delco pump to put in, OEM replacement.
    Pump was really REALLY whining loud so I’m changing it out before I end up stuck somewhere.
    In the box with the new pump comes a new square 4pin connector, but it’s identical to the one already in the car.
    I test fit it to the new pump and it plugs in perfectly. Do I still have to go through the splicing for this included harness for some reason, or can I just plug and play this one?
    Sport Edition Kv5 18x8
  2. #2 Re: Fuel pump wiring harness
    The Boss Iceman6669's Avatar
    Jun 2011
    If it’s identical just use the one on the car. I know at some point they revised the harness and the flat 4 pin was the new design.
    2011 F-150 Yote powered
  3. #3 Re: Fuel pump wiring harness
    Pennsylvania
    Yep, works perfectly with the original harnesses, thank you!
  1. P1260, fuel pump wiring or something
    By suitercrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2020, 02:59 AM
  2. 2003 3.1L Fuel Injector Wiring Harness / No Start
    By peon in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2014, 05:09 PM
