Thread: Direct port methonal injection
Results 1 to 5 of 5
  1. #1 Direct port methonal injection
    SE Level Member Macksauce's Avatar
    Mar 2014
    Maryland
    As anyone run the 6 port split devilsowns direct port meth injection setup ? Im Trying to decide if I want to go that route instead of the dual nozzle setup going into the intake The only obstacle has to be mounting nozzles in these short lim runners right? Come on help me out pros. Full size ic gen v l32 xpz cam 60s is the setup.
  2. #2 Re: Direct port methonal injection
    i run a aem meth kit with progressive controller. i mounted the injector in a tb spacer. if you inject post blower it wont help cool the blower. meth keeps my blower temps to warm. not egg frying hot after a pass at the track.
    before meth i was stuck at 14ยบ wot with a fsic and a 3.2. after meth i got a 2.8 on there and i was up to 19 wot, but now hpt ive got it to take 21.
    so meth got me 6 more degrees of timing and a big drop in pulleys. went from 10 to 12 psi.
    full mod list in my sig.
  3. #3 Re: Direct port methonal injection
    Kemmerer, Wyoming
    i don't think you would need to spray that much methanol. I think you would have a hell of a time finding space for 4 nozzles in the lim. in my opinion, if you wanted to do that, you could add a phenolic spacer on top of your intercooler. in all reality, you could tap the blower in the area of the boost bypass valve and do it like I do.
    edit for more info:
    I recommend emailing devilsown and ask them this question. I spoke with them several years ago, and got some good information.
  4. #4 Re: Direct port methonal injection
    Mar 2014
    Maryland
    Ssorry for late reply guys thanks imma definitely just tap the nozzle into the throttle body spacer leave it at that the check them out didn't know that nothing all get siphoned while you're not in boost
  5. #5 Re: Direct port methonal injection
    Kemmerer, Wyoming
    I have a throttle body spacer for sale that is already tapped for methanol, trying to get 30 bucks for it. I can vouch for the siphoning part. it took me a few gallons to figure out that is what was happening.
    spacer is for an L67 tb though
  1. Direct port nitrous injection
    By Loftus1995 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2015, 06:36 PM
  2. Direct injection
    By dert in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2011, 03:28 PM
  3. Methonal Injection
    By ncccgolf5 in forum Off Topic Discussion
    Last Post: 10-23-2009, 03:50 PM
  4. Methonal...
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 04:52 PM
