Thread: Various gaskets in felpro lim kit
Results 1 to 3 of 3
  1. #1 Various gaskets in felpro lim kit
    Pennsylvania
    Putting my motor back together and I found two different sets of gaskets, I assume they’re to fit various motors?
    Mostly the end seals:
    Gaskets - Album on Imgur
    Sorry I couldn’t get them to embed properly on my phone.
    Im pretty sure I just need the dark blue ones, what are the light blue ones?
    also, it says 6 fuel rail o rings, which I guess go on the injectors to go into the heads, but then theres 6 more fatter o rings that it just labels them as o rings but not what for...
    Sport Edition Kv5 18x8
  2. #2 Re: Various gaskets in felpro lim kit
    Mar 2012
    NC
    One set is for a block with dowel holes and the other is for the other style block. If you have dowel holes, obviously, you know which set you run.
    There's upper and lower injector o-rings. If you didn't pull them from the rail, then don't worry about the uppers.
  3. #3 Re: Various gaskets in felpro lim kit
    Pennsylvania
    Thanks, that’s kind of what I suspected, but I don’t wanna put this together twice so I thought I’d make sure.
    Im glad I finally did this, though, the cars at 150k and the gasket was definitely failed for awhile, I can see the places on the old gasket where the coolant passages were broken and collapsed. So much mess to clean up on the block, outside the lim, on the valve covers and the gasket surfaces.
  1. WTB: ARP Head Studs & Head Gaskets, FelPro or Multi Layer
    By JordanGT in forum Wanted To Buy - Parts
    Last Post: 03-05-2015, 12:51 AM
  2. Replies: 7
    Last Post: 02-28-2015, 07:08 PM
  3. Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    By 01Blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2014, 06:36 PM
  4. felpro or mls gaskets?
    By DaytonaGTP500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2013, 12:04 AM
  5. Felpro vs Thermoseal
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2012, 06:17 PM
