#1
02 GTP rising temp woes.
My 02 GTP has 135k,xxx on the clock, I got it with 98k and did the LIM job then along with coolant elbows and valve cover gaskets. In the past few weeks I've been having trouble with the temperature rising up to point it almost touches the red when the car is idling and the heat goes cold, but when the car is under load the temps are fine and stable. I should also mention here that my low coolant light is going on and off while driving with no rhyme or reason.
About 2 weeks back I pulled the thermostat out thinking it might be bad, and replaced it with a stock temp one. When I did so I noticed there was not much coolant sitting in the LIM, so I added some directly to the LIM through the thermostat housing, replaced the thermostat, topped off the radiator, and the tank. Things were good for about a week, but we're back to the same thing again; rising temps, no heat, etc. etc. Has anyone run into this before? I'm afraid it's sounding more and more like head gasket?
I haven't noticed any excessive smoking from the car or smell of anti-freeze burning, it still runs perfectly fine, no issues at all.
#2
Re: 02 GTP rising temp woes.
02-20-2018
fill the rad, then run it cap of till its getting hot, then rev the engine, if you have bubbles rushing up the rad cap hole, its a head gasket.
the low light is cause its either low. or the sensor is dirty.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
Scottydoggs
I didn't have enough time to let the car cool down and play with it before the sun went down, however I did pop the hood and notice this :
02 GTP slinging mystery fluid 02 GTP slinging mystery fluid - Album on Imgur
Something is being slung around from the belts. The one elbow I can see is dry, but I do see dampness down below the alternator.
Damp below alternator imgur: the simple 404 page
#4
02-20-2018
water pumps do that. drips on the belt, then it slings it all over, the hood too.
#5
Would a faulty water pump be the root of my symptoms?
#6
02-20-2018
it sure can be.
engine off, reach under it, if its wet its leaking.
#7
I could've sworn the sound I was hearing was coming from the alternator (like brushes in a brushed motor going bad). But I suppose it could be the water pump under it.
#8
02-20-2018
you can also engine off, grab the wp pulley with both hands, push and pull with each hand, if you feel play its dead.
#9
I've got a new AC Delco water pump on order, it'll be here today and I'll have a chance to tear into it tomorrow.
Yesterday after work the car was getting hotter than I've seen it before, to the point the Temp light came on and I was having to turn it off at stop lights to prevent it over heating. So this morning I topped off the rad with some pre-mix and drove approx. 5-6 minutes to my parents house to drop of some stuff. Once there the temp had shown it had gone over 210, but the top rad hose was still cool. Drove to work down the interstate and checked it here, the top rad hose was now hot and pressurized (is that normal?)
Here's a quick clip of the sound I'm hearing Water pump noise or alternator? - YouTube
Alternator or water pump?
#10
02-22-2018
hard to say. take the belt off and spin the pulleys by hand, feeling for one thar dont spin free. also run it belt off. to see if that sound is gone.
also snap that sc pulley back and fourth feeling for a slop or play or hearing a click. then you know you need a sc coupler replaced.
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
#11
I'll check that as well, I was actually just reading something about the coupler the other day. Is it normal that top rad hose would be pressurized when the thermostat opens? Or could I potentially have a plugged rad?
#12
02-22-2018
hoses get tight when the temps are hot.
ever flush the coolant? that will tell ya if the rads clogged up or not.
#13
I did a complete flush with a garden hose back when I did the LIM job 2-3 years ago, fresh fill with new dex then too.
#14
Scottydoggs
When replacing the water pump is there a reason to use RTV in conjunction with the gasket? Do any of the bolts need sealant?
#15
02-23-2018
the 4 long bolts get sealant, the small bolts get nothing, and use a dry gasket, no rtv needed at all.
you need to pop the ps pump off, and the lower sc belt idler, might be a t55 socket, or a 15 mm, check what bolt head you got before you tear it apart so you got all the tools you need. pump and idler block a long bolt from coming out on both sides.
#16
Scottydoggs
Any particular thread sealant or just whatever generic liquid I can grab at the local parts store? Any idea about how many gallons of coolant I'll need to grab as well?
#17
02-23-2018
this is what most use. Buy Pipe Sealants - Free Shipping over $50 | Zoro.com
i make my own mix, one gal of straight makes two gallons at 50/50
#18
Ah perfect, just regular PTFE Thread Sealant, I'm pretty sure I've got some of that hanging around. So a good gallon of pre-mix with water should top her back off. Fantastic, today's the day I'll tear into it and see if I can figure out what's going on.
#19
02-23-2018
you'll have coolant left over. but thats ok.
if its newer coolant, get some clear tubing and suck the rad dry, theres a gallon saved right there.
