Thread: Misfire in cylinder 3 ... need help identifying unplugged wire
Results 1 to 4 of 4
  1. #1 Misfire in cylinder 3 ... need help identifying unplugged wire
    Jul 2017
    USA
    I have a 2002 Pontiac Grand Prix GTP that is receiving code P300 - Misfire in Cylinder 3. I have changed the spark plugs and Wires, and I've checked the coils, crank sensors and ignition module... which are working fine however i am still receiving a misfire in cylinder 3. I bought the car used an the previous owner did a hack job under the hood and left wires unplugged so I'm trying to figure out if one particular wire could be the reason why I am receiving code P300.
    I have attached a photo of the unplugged wire in hopes that a member can help me out in identifying where the wire should be plugged.
    Misfire in cylinder 3 ... need help identifying unplugged wire Attached Images
  2. #2 Re: Misfire in cylinder 3 ... need help identifying unplugged wire
    we all got unused plugs under the hood, its normal.
    try swapping #3 injector with 1 or 5, your looking for the miss to move.
  3. #3 Re: Misfire in cylinder 3 ... need help identifying unplugged wire
    Check compression while you are at it.
  4. #4 Re: Misfire in cylinder 3 ... need help identifying unplugged wire
    Jun 2021
    Tune-up replace the plugs and wires and use acdelco parts
  1. Need help identifying a wire
    By 1999GTX in forum Introductions/Noob Questions
    Last Post: 07-16-2015, 08:46 PM
  2. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder 3 Misfire
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 11:24 PM
