On the drive home from work today it was running fine through first and second gear. Seemed when it jumped into third and gave it a little more throttle the rpms dropped instantly to 1200 and wouldnt go back up. I backed off the throttle completely and gave it a little gas it and it was fine. Then a gave it more and the rpms again dropped to right around 1500. Previosly on the highway it seemed like the rpms would hang right around 2200 and ran great, but when i would give it more gas, the rpms would stay in the same spot. Im not sure if this is a trans or an engine issue. Could be a clogged MAF even a glogged cat. Also I think im burning some coolant too. Could be the issue clogging the cat. Anything helps guys. Its my onl form of transportation so hopefully this will be a cheap fix. Thank guys
