^^That.
Quote Originally Posted by dbest1197 View Post
Ok so recently as in like the last 2 days the car has started spitting and sputtering again and one thing that I would think points to the converter being melted is that it constantly tries to overheat on the interstate or just idling and this is with the heat at FULL BLAST, but if your coasting down a back road with the heat at about half it runs at normal temp. It's also back to where 9/10 times when you crank it up you have to give it gas for a second to keep it running
Sent from my SPH-L720T using Tapatalk
Quote Originally Posted by blueguy View Post
lol wut.
Autolite 606's. Gap the plugs @ .050" and never worry about them.
Get generic lifetime warranty plug wires, and clean the coil pack terminals as well.
Get a 2.5" or 3" catted downpipe from ZZPerformance. Take it to a shop and have them install it if you can't with a jack and hand tools. It'll be cheaper anyways.
Did you read this?
Or did you just not read it?
