Thread: zzperformance powerlog
Results 1 to 14 of 14
  1. #1 zzperformance powerlog
    Jan 2009
    Hello everybody,
    I have a question about the zzp powerlog. I want to buy one along with my 3" downpipe, but see that they want an extra $80 for the ceramic coating. I was wondering if it was really needed to pay the extra money for it, or will the standard version be just fine and do the trick?
    Thanks
  2. #2 Re: zzperformance powerlog
    SE Level Member TehGTP's Avatar
    May 2008
    Saint Louis, MO
    the plog in general prolly isnt really worth the cash.
    i have a ported front manifold i could sell you that would give you almost the same results at a 1/4 of the cost.
    2007 Corvette Z06 - BFD Cam / E85 / milled & fixed heads
    2006 GTO M6 18's - SOLD - VRX5 Cam | FAST 102 | Exhaust
    2001 GTP - SOLD - 1.9 | TOG's | E85 | LC1 | B+G | AGX | GMPP | 3EP
  3. #3 Re: zzperformance powerlog
    a plog != a ported front manifold. the plog is a great buy for the money it is. if i would buy one id just get it regular and wrap it with header wrap.
  4. #4 Re: zzperformance powerlog
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    a plog is a little more than a just an OEM manifold that is ported by someone with a dremel. I've got a regular plog w/hi temp black paint. The black paint turned gray after the first 10 min. and it hasnt changed since.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  5. #5 Re: zzperformance powerlog
    Barksdale AFB, LA
    Quote Originally Posted by TehGTP View Post
    Ported manifolds are nowhere near the Plog. The problem with the stock manifold is not the primaries, but the diameter of the collector area which you simply cannot port. My Plog is stainless and still looks like day one.
    2009 Subaru Impreza WRX STI
  6. #6 Re: zzperformance powerlog
    May 2008
    Saint Louis, MO
    my 2gen plog cracked at every primary after 4 months, no wrap no paint just as it came from them.
    no help from zzp, thanks.
  7. #7 Re: zzperformance powerlog
    Barksdale AFB, LA
    Mine's fine, six months into the install. Even had it so hot it was glowing, one time.
  8. #8 Re: zzperformance powerlog
    Jan 2009
    Thanks for the info so far. I'm gathering that it really doesn't matter if is ceramic or the black high temp paint, just the black paint will burn off quickly after install.
  9. #9 Re: zzperformance powerlog
    the ceramic coating will hold in heat better, but is it worth it on a plog? probably not.
  10. #10 Re: zzperformance powerlog
    Donating Users chrisb's Avatar
    Bucyrus, OH
    i think they need to make them heavier. mine crack after 7 months on a n/a car.... maybe 14 gauge stainless? just somthin so they last longer. nuthing like spending 200 and having it crack just over half a year later
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  11. #11 Re: zzperformance powerlog
    Jersey
    A dremeld job manifold is no where near the same as a plog...there had been too many complaints on zzp's high temp paint making lots of smoke, smelling like shi*...blah blah blah... I got mine with ceramic coating, i mean its +$60 for stainless and +$80 for ceramic, i thought i might as well get it in ceramic for the extra $20, even though most of it scratched off anyways while installing... oh and id say if your car is a bit older to get new exhaust manifold bolts...
    16' wrx sti- stock
  12. #12 Re: zzperformance powerlog
    Barksdale AFB, LA
    Get stainless. Stronger, holds heat about as well as ceramic, and won't scratch or flake. I mean, the true test to me of the stainless was when it was glowing. I could put my hand down near it and barely feel any heat coming off, but it was pretty damn bright. Also my ceramic coated x-over didn't have hardly any radiant heat either.
    (Note, I didn't do that on purpose. Had the car idling to warm up on a cold morning, stuck IAC causing a 2500RPM idle, and about 20 minutes of sitting there doing it before I came out and realized. That's a lot of exhaust heat).
  13. #13 Re: zzperformance powerlog
    SE Level Member jims05ss's Avatar
    Stainless FTW. Had mine on for about 1 1/2 years now with no problems at all. Previously had a 1st gen plog that did eventually crack at the primaries.
    05 Impala SS; 13.84 @ 100. SSIC, 3.25 pulley, 1.9's, PRJ tuned PCM, ZZP SS P-log, ZZP SS 3" DP, ZZP TB spacer, 4" FWI w/9" K&N, U-bend & resonator delete, Magnaflow cat, wrapped crossover, 180 t-stat, PRJ Wires, 103's, Royal Purple, Eibachs, front & rear STB's, Aeroforce.
  14. #14 Re: zzperformance powerlog
    Feb 2008
    South Bend, IN
    damn, kind of wish i would have splurged for a stainless now. ah well.
  1. Hulkspeed PEM vs. ZZP Powerlog
    By 04CompG in forum General Tech Discussion
    Last Post: 11-19-2008, 06:12 PM
  2. Powerlog and 10.4mm PRJ's
    By whitelightnin04MC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2008, 01:10 PM
