Thread: Coolant?
Results 1 to 10 of 10
  1. #1 Coolant?
    SE Level Member james782004's Avatar
    Nov 2015
    Any ideas where my coolant is wandering off to? No leaks no milky sledge under oil cap. I'm at a loss here temp guage goes up to 212 after only a few mins from a cold start. I don't see any mess under hood or on ground.
    Sent from my SM-G920R4 using Tapatalk
  2. #2 Re: Coolant?
    It could be burning/eating it.
  3. #3 Re: Coolant?
    Nov 2015
    How can I fix that?
  4. #4 Re: Coolant?
    Nov 2015
    No lights on aside from abs.
  5. #5 Re: Coolant?
    Hard to say, a cooling system pressure test is what I would do first to rule out any leaks.
    On the off chance a headgasket went you could do a hydro carbon test of the cooling system to check for exhaust gases in it. Look for white smoke out the tail pipes on start up.
    Past that I would be tearing the top end down and looking at LIM to TB coolant passage and intake gaskets themselves for internal leaks.
  6. #6 Re: Coolant?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Check your coolant elbows, if your losing it slooooowly, they can weep and it burns off/evaporates B 4 it hits the ground.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #7 Re: Coolant?
    Nov 2015
    They've been changed to aluminum ones not sure if that matters, maybe they are on wrong and loose. Ty
  8. #8 Re: Coolant?
    Nov 2015
    Update: I did notice that when the car runs and is hot the hose that connects to the thermostat collapses.
  9. #9 Re: Coolant?
    SWPA
    Could be something as simple as a bad rad cap. It will allow coolant to evaporate past the cap and you'd never know you were losing it from there.
  10. #10 Re: Coolant?
    Quincy, Mass
    I'd start by replacing the hose. Radiator could also be clogged with some dexcool sludge
    No more GP 04 Impala SS Indy:
  1. LIM side coolant port modification / coolant block off
    By 2004l67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2015, 02:56 PM
  2. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  3. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
