Thread: anybody every used the cheap Ebay OBX headers??
Results 1 to 17 of 17
  1. #1 anybody every used the cheap Ebay OBX headers??
    SE Level Member 98GTXDAYTONA's Avatar
    Jan 2009
    Mayville, WI
    They seem like such a great deal, stainless polished headers and for just over $300 But are they not worth it? Do they fit the car at all? I just hate to spend $600-800 for a set of SLP or Pacesetter headers if these will work just as good.
    Any input would be greatly appreciated. Thanks.
    Here is a link to the headers:
    eBay Motors: OBX HEADER EXHAUST 97-03 PONTIAC GTP BUICK REGAL GS 3.8 (item 160297364965 end time Feb-05-09 16:36:56 PST)
    1998 Daytona 500 Pace Car #580/1500
    Factory SLP GTX Ram Air Package 1 of 27
  2. #2 Re: anybody every used the cheap Ebay OBX headers??
    SE Level Member TehGTP's Avatar
    May 2008
    Saint Louis, MO
    we just put a set on this week, fit great, great quality, great welds, my only advice would be have the rear welded to avoid leaks, and the crossover will need to be cut and rewelded to line up right.
    they dont install themselves by any means, but an awsome buy and a great product for the money. i would recommend them.
    2007 Corvette Z06 - BFD Cam / E85 / milled & fixed heads
    2006 GTO M6 18's - SOLD - VRX5 Cam | FAST 102 | Exhaust
    2001 GTP - SOLD - 1.9 | TOG's | E85 | LC1 | B+G | AGX | GMPP | 3EP
  3. #3 Re: anybody every used the cheap Ebay OBX headers??
    SE Level Member Infinity9999's Avatar
    Dec 2008
    Brookfield, WI
    I've had them on since before Christmas. They work pretty well. As mentioned, they need to be modified some, unless OBX actually got the messages people have left them and have corrected the crossover orientation. You will also need to cut part of the front manifold flange off so that it fits (they used the same flange on the front and the rear, so the front has the EGR hole too). Get the Y welded to avoid leaks. And you will probably have to deal with the 3-bolt flange between the Y and the flex as it will probably hit the bottom of your car (at least mine does). I'm looking into getting the flanges cut off and replaced with a V-band flange/clamp set.
    Otherwise the SS AutoChrome (aka X-S Power) ones which are the SLP knockoffs are recommended as well and cost the same.
    04 Black GTP Comp G
    Mods: 3.2 pulley, SSIC, Wizair, AL104s, OBX headers, VS cam, 105# springs, 42# injectors, PowrTuner
  4. #4 Re: anybody every used the cheap Ebay OBX headers??
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    There are ones on ebay that cost $188 + $50 for shipping
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  5. #5 Re: anybody every used the cheap Ebay OBX headers??
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    They dont sound that great if you have to modify them just to get them to fit.
    Yes they are cheap and i see why.
    When i got my togs there was no fitment issue. Everything was the way it was suppose to be. But also looking at double the price
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  6. #6 Re: anybody every used the cheap Ebay OBX headers??
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    im looking into the ss autochrome & the s&s raw headers. what are the pros & cons between the two? does anyone recommend one over the other?
  7. #7 Re: anybody every used the cheap Ebay OBX headers??
    SSAC = slip fits.
    S&S = donut gasket and flange
    SSAC = 3 piece headers
    S&S = 2 piece headers
    SSAC = stainless?
    S&S = steel w/a coating if you get it
    i love my S&S. they were cake to install and seal, unlike the used set of TOGs that i had on the car previously that i never got to seal. they say they have smaller primaries and are for more of a lightly modded car, but i havent seen them as any type of restriction in my setup yet. i bet they are good for whatever you can throw at them since you can barely push 400 whp on a max build blower setup.
  8. #8 Re: anybody every used the cheap Ebay OBX headers??
    Jan 2009
    westport maSS
    SSAC = slip fits.
    SSAC = stainless?
    im def leaning toward the S&S headers! i wont be able to buy them coated but i might paint them or wrap them im not sure what would be better!!
    Going back to stock *GRANT built trans BLOWN w/17k*
  9. #9 Re: anybody every used the cheap Ebay OBX headers??
    if i were to do it over instead of getting the ceramic coating i would have just gotten them regular and wrapped them nicely. they probably would have performed better with the wrap too.
  10. #10 Re: anybody every used the cheap Ebay OBX headers??
    Jan 2009
    westport maSS
    ya the header wrap is not to much money either. ive just never wraped anything before, do you think it would be fairly easy to wrap them nicely myself?
  11. #11 Re: anybody every used the cheap Ebay OBX headers??
    yep. just take your time and seal them right. a lot of people have different ways of doing it. the most common is DEI (?) header spray, kinda like paint. i have also heard to people shmearing RTV all over it.
    i guess that is something youll have to figure out on your own because i have never wrapped a set of headers before.
  12. #12 Re: anybody every used the cheap Ebay OBX headers??
    Jan 2009
    westport maSS
    cool thanx for the input man!!
  13. #13 Re: anybody every used the cheap Ebay OBX headers??
    May 2008
    Saint Louis, MO
    Quote Originally Posted by 05SS45 View Post
    yep just take your time, no big deal and make sure you have clamps on hand to hold it in place.
  14. #14 Re: anybody every used the cheap Ebay OBX headers??
    Quote Originally Posted by TehGTP View Post
    AND FOR GOD'S SAKE WEAR GLOVES
  15. #15 Re: anybody every used the cheap Ebay OBX headers??
    Jan 2009
    westport maSS
    cool man thanx alot i wouldnt have thought of that.
    lol i usually wear gloves when i work on cars.
  16. #16 Re: anybody every used the cheap Ebay OBX headers??
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Ya I wish I wasn't lazy or else I would have definitely wrapped mine, the ceramic coating on my headers isn't in the greatest shape anyway lol.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  17. #17 Re: anybody every used the cheap Ebay OBX headers??
  1. Cheap ebay intake
    By wildkyle90 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-19-2008, 11:26 AM
  2. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
  3. Ebay Headers
    By PhilsGTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 12:22 AM
  4. Cheap rotors/pads from Ebay(R1 Concepts)... You opinion is requested!!
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2008, 10:07 AM
