Thread: Oil pan gasket
Results 1 to 7 of 7
  1. #1 Oil pan gasket
    Jul 2016
    Cedar City Ut
    Ok another stupid question. So I'm putting on a new oil pan gasket (felpro) on my 2005 GP GTP. Open the box and it's got this cool looking gasket with the "plastic pan". Inside my oil pan is a metal pan that's bolted in. Do I leave that metal pan in and just let the plastic sit on it / near it? I googled the crap out of it but can't find anything.
  2. #2 Re: Oil pan gasket
    Pictures?
    I thought the aluminum oil pans used grey RTV only with no gasket.
  3. #3 Re: Oil pan gasket
    Antioch, IL
    Aluminum pans do get sealer no gaskets you are correct.
    http://www.grandprixforums.net/threa...n-aluminum-one
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Oil pan gasket
    Jul 2016
    Cedar City Ut
    And yes the pan is getting cleaned before it goes back in.
  5. #5 Re: Oil pan gasket
    Jul 2016
    Cedar City Ut
    Thanks for that link I would have completely messed up with out it. Im swapping a steel pan for the aluminium I would have been screwed had I not known to swap the pick up tube also...... Thanks FFDP and Ithurtz I'm a little lost right now. I'm using a Series 2 block but swapping everything from my series 3 onto it.
  6. #6 Re: Oil pan gasket
    Jul 2016
    Cedar City Ut
    Heres the pics, So I dont need this gasket just gray rtv? That would be some what simpler.
  7. #7 Re: Oil pan gasket
    That gasket is for the older metal pans.
  1. Head gasket problem, 25 miles on new gasket
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2014, 04:25 PM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
