Thread: throwing code p0742 tcc
Results 1 to 14 of 14
  1. #1 throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    I'm throwing a code for the torque converter clutch solenoid. I've watched a few videos, i'm guessing the only way is to drop the front engine cradle, remove the suspension in the way and get access to the trans that way? Should I replace the transmission oil pressure solenoid, the shift solenoids, and the tcc as well while I'm in there?
  2. #2 Re: throwing code p0742 tcc
    Mar 2014
    Tucson
    1.) Yes
    2.) Depends. There are a lot of variables. How many miles on the trans? How long do you plan to keep the car? Etc... You can replace all four solenoids for under $100. That's for the good BW PCS and TCCS.
  3. #3 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    not what i wanted to hear, even though I figured that was the answer
  4. #4 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    could anyone shed some light? is this video helpful for replacing this piece
    https://www.youtube.com/watch?v=b7AIX4jEtJ4
  5. #5 Re: throwing code p0742 tcc
    Mar 2014
    Tucson
    Eh, kinda. But not really. You don't need to pull the pump apart. You can get to all the solenoids by just removing the side cover.
    I found this series to be helpful.
    https://www.youtube.com/watch?v=oTVpIod6Eas
    https://www.youtube.com/watch?v=QgLSTyTd27s
    https://www.youtube.com/watch?v=JRkAa-whRi0
    https://www.youtube.com/watch?v=2xEuFj8wRp4
  6. #6 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    that's great man, thank you. so pretty much once I get access to that side panel, it shouldn't be too bad.
  7. #7 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    how necessary is unbolting the steering?
  8. #8 Re: throwing code p0742 tcc
    Mar 2014
    Tucson
    Not necessary at all if you unbolt the rack from the cradle. One or the other.
    Have to support/strap the rack if you do it that way. ^^^
  9. #9 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    will do thank you, did you replace the filter as well?
  10. #10 Re: throwing code p0742 tcc
    Mar 2014
    Tucson
    If you're dropping the pan, I think it would be silly not to. They're like $15. And since you're that far, might consider a shift kit as well.
  11. #11 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    yeah, I got all 4 solenoids to replace. I guess I'll get a filter too.
  12. #12 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    sooo, do I unbolt all 4 subframe bolts?
  13. #13 Re: throwing code p0742 tcc
    Mar 2014
    Tucson
    Start by loosening the right side all but a couple turns. Remove left side bolt completely.
  14. #14 Re: throwing code p0742 tcc
    Banned
    Jan 2013
    Colorado
    guess i'll put those ones back in
  1. P0742 Torque converter code
    By bainjeep93 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2016, 11:48 PM
  2. Emergency help needed.. P0742 code
    By hunter_alexander in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2012, 07:51 PM
  3. P0742 Code - should I pay for repairs or just sell the car?
    By Deezul_AwT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2012, 05:56 AM
  4. p0742 code
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2010, 05:24 PM
  5. code p0742
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-25-2009, 02:16 AM
