Thread: Engine build/rebuild first time
Results 1 to 18 of 18
  1. #1 Engine build/rebuild first time
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    So this summer I plan to lose my stock motor viginity and build a motor on a stand! But I'm in need of some help and direction.
    I'm debating back and forth between a 3800 or a SBC.
    Either way, I have a few questions:
    1. If I don't want to "rebuild" per say, like the rotating assembly is is good shape, do I need to do any machining? Minor machining is fine but I wanna avoid costs in that department.
    2. If I replace all the bearings, is it okay to reinstall stock rods and crank without machining?
    3. If I do get a block that's .030 over already, pistons need to match right? What about the rest of the rotating assembly?
    Thanks in advance, also gimme some votes on 3800 vs SBC! Lol
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: Engine build/rebuild first time
    Kemmerer, Wyoming
    I wouldn't do either. I just bought a 1994 Chevy Suburban 1500 with a TBI 350. it makes about 200hp/300tq. the small block route is going to end up costing at least 1500 to make 300hp/300tq. many people are doing a modern LS 5.3 swap because those engines cost about 500 dollars from the junkyard and make 300/300, with a tremendous amount of potential.
  3. #3 Re: Engine build/rebuild first time
    The hell would you put a 350 in a WBody, for?
    If you're putting a motor in a WBody, get an L36...toss some decent punched out heads on it with a cam, let it breathe and you're good to roll.
    For the latter, LS swap it. Whatever it is. Heads/cam LS will poop on most anything 350~ related for the money.
  4. #4 Re: Engine build/rebuild first time
    Feb 2014
    Rhode Island
    I had those 2 motors in mind becasue the 3800 could go in my GP or the SBC could go in the '68 firebird we have
  5. #5 Re: Engine build/rebuild first time
    LS swap the **** out of that thing. I wouldn't even consider anything else unless you had an old school BBP to toss in it.
  6. #6 Re: Engine build/rebuild first time
    Kemmerer, Wyoming
    the small block 350 route is old school, nothing wrong with it, but the technology has been the same since the '50's. one problem with the small block is the ridge that happens at the top of the engine block because the pistons wore it down. the LS 5.3 will not ever have that problem because the materials are so much better. even my 200,000+ L67 motor had no ridge. I've been thinking about doing a small block build for the 1994 suburban I bought, but for the money it makes no sense to build a small block. a good set of heads alone will cost 1000 dollars for a small block.
  7. #7 Re: Engine build/rebuild first time
    Feb 2014
    Rhode Island
    I have been trying to rally for the LS swap but my dad says it's gonna be WAY more work than just building a motor lol maybe if I just do it, he won't have a choice haha
  8. #8 Re: Engine build/rebuild first time
    Feb 2014
    Rhode Island
    Also, so what I'm understanding is that you don't need to go .030 to build up an LS or 3800 even if it's used?
  9. #9 Re: Engine build/rebuild first time
    Kemmerer, Wyoming
    Quote Originally Posted by Dadkota View Post
    machine work on a 3800 is often counter productive because people have problems with the engine after it's installed, and on an LS, the cost outweighs the benefit. there are some good guides on LS1tech.com on doing a swap. a swap typically involves installing a fuel pump in the tank, getting the pump wired in, maybe running the coolant line from the radiator to the engine on a different side, different motor and transmission mounts, and depending on what transmission you use, you may need a stand alone wire harness for the engine and/or transmission, or you can have the wire harness modified for the vehicle it's going in.
  10. #10 Re: Engine build/rebuild first time
    Lets put it this way, there is no building a 3800. The second you unbolt the main cap/rod cap it's straight to a machince shop for hundreds and hundreds of dollars worth of work and most motors that get "rebuilt" or "built" end up dying within the first 100 miles because something wasn't done right. The 3800 is very picky about certain things and even making it a bored over stroker motor isn't worth the money.
    The SBC 350 works and that's a given but the cost to build one is more money than what a 5.3 LS motor can already make in stock form or just with a small camshaft upgrade. Figure roughly 200-250 crank hp stock for a SBC and 285-315 crank hp stock for a 5.3 LS motor depending on year.
    The LS based motors don't even need machine work if you take them all the way apart, if the rod bearings look great and the cam bearings are still nice you can slap them back together with no real worry because it'll run just fine.
    If you go the LS route, I suggest trying to fine a mid 2000's motor for the extra bump in horsepower and better heads but then use a cable throttle body setup and computer from a 2001-2002 silverado. Cable setups are easier to use on a older vehicle swap, no need to wire in a DBW throttle pedal or any of that jazz. If you use the same year harness as the computer with a drop in 4L60e to match, tuning will be easy. Disable the VATS, delete the emissions codes and it will run just like a stock truck motor.
  11. #11 Re: Engine build/rebuild first time
    Feb 2014
    Rhode Island
    If I go LS, would the eventual swap into a Camaro/Trans Am be relatively simple? I definitely want to avoid the machine shop as much as possible
  12. #12 Re: Engine build/rebuild first time
    It's not very complicated to do the swap, might take a custom part here or there though.
    They make aftermarket motor mount conversion brackets and crossmembers for these swaps. It might need a different oil pan if the truck pan is too large. I think people run the LH8 pan, from like a hummer because it's shaped a little different and doesn't hang down as far.
    Then you have the exhaust which will have to be custome made for than likely.
  13. #13 Re: Engine build/rebuild first time
    Feb 2014
    Rhode Island
    That isn't that bad, and way down the line anyway lol
  14. #14 Re: Engine build/rebuild first time
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    We're doing an old school 427/T56 swap on the '68 Firebird we've got. Don't go small block, either big block or LS. It's just not worth the money, and the swaps are being made simpler by aftermarket stuff, especially for the 1st gen F bodies
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  15. #15 Re: Engine build/rebuild first time
    Quote Originally Posted by PaintChips97 View Post
    I hear the first gen F bodies are really easy to LS swap anymore. So many companies that make plug and play harnesses and stuff.
  16. #16 Re: Engine build/rebuild first time
    Feb 2014
    Rhode Island
    427!? That's sweet! There is a cammed, 4barrel 350 in it now. But I have looking to take on a project for it
  17. #17 Re: Engine build/rebuild first time
    Apr 2015
    Illinois
    Quote Originally Posted by Slick2500 View Post
    ^this is exactly right. Almost nothing custom is required anymore, it's all available from vendors
    Nice! Ours has a 400, 4 barrel, and it definitely sounds cammed to me, but we didn't put it together lol. Yeah, the 427 is gonna be fun (the little bitty stroke in those things makes them run like hell), I'm really looking forward to the 6 speed though. It's got a TH400 with a shift kit in it now
  18. #18 Re: Engine build/rebuild first time
    Feb 2014
    Rhode Island
    We almost picked up a 455 Pontiac for it but it feel through sadly lol We have the TH350 with a kit too lol it will chirp gears but I would love a manual!
  1. Replies: 324
    Last Post: 12-05-2014, 04:19 PM
  2. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  3. Time for more POWAAA! (GEN V Build)
    By AmericanSoldier in forum General Tech Discussion
    Last Post: 11-03-2011, 08:07 PM
  4. Time for a rebuild? 04" GP GT
    By SilverbulletGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-06-2011, 10:23 AM
  5. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
