Thread: Just got car now knocking
Page 12 of 12 FirstFirst ... 2101112
Results 221 to 237 of 237
  1. #221 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    No way that will be enough.
    What do you suggest?
  2. #222 Re: Just got car now knocking
    GTP Level Member
    Aug 2012
    st louis park, MN
    There is a gasket between the rear manifold and the downpipe. It's a metal crush bent gasket. You can use copper rtv instead if you want. The gasket is a one time use only.
    So I disconnected my downpipe during a rack replacement and reinstalled the gasket not knowing it was a 1 time use. I suspect a slight exhaust leak now and it sounds like that would be expected based on what you know?
    Thanks for clarity on my suspicion!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  3. #223 Re: Just got car now knocking
    I've re-used that gasket several times before, haven't had a leak there.
    Maybe I'm just lucky and never damaged it.
  4. #224 Re: Just got car now knocking
    May 2008
    Schuyler, NE
    That's a crush bent gasket. One time use only, or it won't seal. Similar to the way a compression fitting works under your sink. If you reused it without a leak, you either have the felpro replacement, or you are stupid lucky.
  5. #225 Re: Just got car now knocking
    I think I've had the downpipe out of my sisters car like 3 times already and everytime I just impact the bolts back on and send it. No leaks FTW.
  6. #226 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
  7. #227 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Just to make sure do I drop timing only at wot or all across the board?
  8. #228 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    What I did right now with hptuners is drop timing by seven degrees from 5000 Rpm and up
  9. #229 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Also would bad ground or bad battery cable make theft light come on
  10. #230 Re: Just got car now knocking
    why so much timing removed? seems like a lot to pull. set to 13-14 of your knocking like mad or something. -7 is like 8º, thats weak for sure.
  11. #231 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Oh ok I just wanted to make sure but I just cranked it up again and it's rattling or something. I might just run it back through the auction and get what I can out of it
  12. #232 Re: Just got car now knocking
    take the sc belt off and see if the pulley has slop in it, turn the pulley back and fourth, snap it back, if it clicks its just a bad coupler. they tend to make a racket at idle when bad. like rocks in the sc horrid sound.
  13. #233 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Where are all the grounds? I ha e a connections issue. With key on the check engine light flickers and the power train relay clicks really fast. Is the fuse box going out
  14. #234 Re: Just got car now knocking
    tranny bolt has a stud on it, follow the neg cable if you dont see it right away. its under the cross over pipe somewhat. theres smaller grounds there as well, the wires tend to break off the eyelets sometimes, theres also a ground off the battery to the fender on the 04 up cars iirc.
  15. #235 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Ok that's what I thought. Thanks allot you've been a great help. Im going to upload a video of what is doing
  16. #236 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
  17. #237 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Here's another video https://youtu.be/HGvN91PhJLA
  1. knocking
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 01:34 AM
  2. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  3. 99 GTP Knocking
    By BoNeZ in forum General Tech Discussion
    Last Post: 10-28-2010, 05:52 PM
  4. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  5. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
