Thread: Just got car now knocking
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 21 to 40 of 237
  1. #21 Re: Just got car now knocking
    Just pull the dipstick, if you see sparkles that motor is dead.
  2. #22 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    I did. Oil is clean surprisingly. Would coolant leaking into engine cause rattle?
  3. #23 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Just to make sure I have this right. To run the non supercharged engine, I need headers? What's supposed to be in the tune? I can run the cheap 200 Ebay headers?
  4. #24 Re: Just got car now knocking
    the tune needs to be changed to a gtp file, map sensor and it pig tail need to be swapped on the na car too. you need headers so it can flow better, and yes speed daddy $200 headers are what a lot of us run.
  5. #25 Re: Just got car now knocking
    Scott, you need to read more lol.
    It's already a supercharged car, nothing would have to wired in nor the tune changed for that reason.
    The tune just needs adjusting because the NA bottem end is the difference.
  6. #26 Re: Just got car now knocking
    i got lost with the other guy with 2 engines and what to do lol
  7. #27 Re: Just got car now knocking
    Feb 2013
    37.295091, -121.930053
    well bill never got lost scott you should learn from him
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #28 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    One more thing. To turn crank by hand, do I need to put in drive or neutral?
  9. #29 Re: Just got car now knocking
    nope. turn engine at will with the crank bolt or the flex plate.
  10. #30 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    It's locked up. I just tried to turn it. Not one ounce of a budge. In order to unlock I have to release rods from crank?
  11. #31 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    I found water in the oil. I checked it after I changed the spark pugs and took for test drive. It was clean. Now I just checked it and it's muddy
  12. #32 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    I found an n/a engine for 436 at lkq. I'm going to do a top end swap. What's the torque sequence and numbers for the head bolts? And will the engine light be on running an n/a bottom end?
  13. #33 Re: Just got car now knocking
    well at least the one rod to the locked up piston, you maybe able to put a breaker bar on the crank bolt with a pipe and make it move again, its trash but they do break free some times. as long as it didnt get to hot.
  14. #34 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Oh ok. No It Didn't Get Hot. One thing I do on all my cars is watch the gauges like a hawk
  15. #35 Re: Just got car now knocking
    436 that's pretty cheap nice
    04 Comp G.
  16. #36 Re: Just got car now knocking
    Quote Originally Posted by Warriorpluto View Post
    to run a na bottom end you need headers and likely need a tune.
    thats what im running now. bottom swapped set up, mods in my sig. my car came with a l67. it needs the timing lowered one degree for sure in most set ups.
  17. #37 Re: Just got car now knocking
    http://www.grandprixforums.net/threa...s-of-3800-Info top swap thread, has the head tq and pattern
  18. #38 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Thanks for those links and for being so helpful. I'm just learning about these engines. Only engine I've ever owned is an ls and ford 302
  19. #39 Re: Just got car now knocking
    if your plan is to re use your heads, make sure you find a blown head gasket, cause a cracked head or blocks the only way the l67 leaks coolant into the oil.
  20. #40 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Ok I will. Hopefully the heads aren't trash. I'll take them to the machine shop and get them cleaned and checked. Now what's this about timing being retarded? You tune these also?
  1. knocking
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 01:34 AM
  2. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  3. 99 GTP Knocking
    By BoNeZ in forum General Tech Discussion
    Last Post: 10-28-2010, 05:52 PM
  4. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  5. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
