So I just bought a set of .052 4 layer Cometic gasket from zzp. The only option they had for bore size was 3.84.
My question is they say not to run a 3.84 bore gasket on a stock bore motor, has anyone ran this type of gasket on a stock bore engine.
I'm running 9.8 to 1 compression on a na short block with 16 psi on a gen v with fully ported heads, and spraying 10 gal per hour of water meth. I'm using arp head studs and will be using copper gasket spray with it as well.
Sent from my SAMSUNG-SM-G920A using Tapatalk
