I ran 20° of timing at 12.0 afr wot with 0 kr all the way through the shifts on 91 octane pump gas
Sent from my SAMSUNG-SM-G920A using Tapatalk
Nice. Pm me ur cellphone number
https://youtu.be/ObxE9HL0rDw
I installed the stock Throttle body. Here is a roll on clip up to about 70 mph. KR and Ign. Adv. values.
Time to put a stock throttle body back on it or get an actual tune.
160* doesn't matter, proven they actually run 10-15* hotter than the listed temp. My 160* cars always sat around 175*~, which is enough to have the knock sensors report (anything less than 169* I don't think they give a sh1t).
As for the rest of the mods. TB spacer is worthless, throw it out. Iridium plugs? Nope. Chuck them. Get cheapo 104 copper plugs.
Rockers, headers, tune, and a 3.4" should be just fine knock free with at least an 04+ timing table.
What gasoline are you running? E-10? E-15? Is it brand name, or from the crappy gas station that sells really cheap (but really old) gas?
BP 93 octane. 10% ethonol.
I just bought some copper 104s. I will get them in today or tomorrow and video another pull.
I just replaced the o2 and I am getting an o2 slow response code now. I just figured it was the original with 93,000mi it wouldn't hurt to put a new one on. This is a denzo.
What o2 does everyone else run?
ac delco from amazon. this is the upstream.
http://www.amazon.com/gp/product/B00...ilpage_o09_s00
I shop on amazon more often because I am a prime member and get free shipping a lot.
Is it a 1133 code??? All that is saying is that it once the car reaches closed loop mode that it didn't switch between rich and lean enough times in a given amount of time. I think GM cars is 90 seconds is how long it runs the test, figure it wants to see 60 switches but it saw 55 or 58 more than one time it will set the code. I dealt with it when I did headers and after a few times it stopped popping up.
If so, just clear it. It's a pretty common code anytime you have headers or aftermarket manifolds to the car.
Good thing you're paying attention, Cam.
Way to save the day.
