I have an 06 supercharged 3.8. My trouble is that I will be driving along and the car kicks my cruise control off and flashes the check engine light at me. You can't ever feel a misfire, but the code it sets is for cyl 1 misfire. I have performed cyl leakage test with good results, new plugs & wires, switched coil packs ignition modules and fuel injectors with no change in my problem. Has anyone experienced this problem and solved it?
