Thread: cam opinion
Results 1 to 7 of 7
  1. #1 cam opinion
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    just wanted 2 get everybody's opinion on a cam.what cam' are good? if I should even get a cam? I am getting the ssm90 kit with a 3.4 pulley,and after knowing what I know now about the NIC cam I was thinking about the xp cam bcuz I don't have any access 2 wideband tuning for the NIC cam.thoughts? (keep n mind im looking 2 run n the low 13's)
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  2. #2 Re: cam opinion
    you dont need a cam to run low 13s. rockers will get you there easily and they are cheaper, easier to install, and easiest on the valvetrain.
    rockers, headers, ~3.2 pulley, maybe a ported blower/throttle body, and the rest of the supporting mods with a good tune will get you in that power range. that will get you there if you can get a good launch.
  3. #3 Re: cam opinion
    Barksdale AFB, LA
    3.2" on a L36 block will be kinda intense... I'm not expecting to run lower than a 3.4" with everything I'm doing.
    2009 Subaru Impreza WRX STI
  4. #4 Re: cam opinion
    Jan 2009
    Baltimore
    well I think u need a gtp balancer 2 run anything under a 3.25,ssm90 dosent come with that.but idk I love the sound of a cam lol
  5. #5 Re: cam opinion
    didnt realize we were talking an l36 block. get a cam if you so desire, but there is no reason for one if you only want to go lower 13s.
  6. #6 Re: cam opinion
    TDCRacing
    Guest
    If you are wanting i'd get an XP. I have/had one and I liked it. That cam will put you in real low 12's with an intercooler.Without...maybe 12.7's?
  7. #7 Re: cam opinion
    TDCRacing
    Guest
    Also, I'm about to gp with a custom cam from comp. So i will also recomend that.
  1. I need your opinion...
    By SLO-6 in forum Tires & Wheels
    Last Post: 10-19-2008, 08:36 AM
  2. Hp tuners 2nd opinion
    By snap on in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2008, 05:28 PM
  3. opinion
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-18-2008, 04:59 AM
  4. Could use an opinion or two
    By fratzke7 in forum Off Topic Discussion
    Last Post: 07-10-2008, 07:40 PM
  5. need your opinion...
    By miss prixx in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:53 PM
