2002 Pontiac Grand Prix
3.8L - unmodded
180K miles
Please read entire description, Im sure there have been similar post to this issue since the 3.8s are notorious when it comes to stalling. So here's the situation.
Car stall randomly, it can be while driving on the freeway foot on the accelerator, or sitting at a light idle. When car dies, I get all indicator lights as if i just put the ignition switch in the "on" position. I do NOT get a "service engine" light when this occurs, this being said there are no codes to be read.
Thus far I have;
Checked fuel pressure - good at 45 psi
Replaced the crank position sensor
Replaced the cam position sensor
Swapped ignition control module (with known good one)
Swapped coil packs (with known good ones)
Generally, from what I have read, the crank position sensor is the culprit. In this case, with it being replaced already Im second guessing myself.
What i do find odd is that I am unable to induce a PCM/ECM fault. I have pulled a plug wire which should give me a "service engine" light but did NOT. I have also pulled multiple sensors as well as an injector cannon plug, still unable to induce a "service engine" light. The "service engine" light does work as I am able to turn it on/off with the use of a 2 way code scanner (Autel Maxidas).
Could I have a bad PCM/ECM? Could this be the issue to my stalling randomly? Is there anyway to test the component?
Help please.
EA
