Thread: 02 Grand Prix Constantly Misfires
Results 1 to 20 of 28
  1. #1 02 Grand Prix Constantly Misfires
    Jun 2014
    Nappanee, IN
    I've had my GP for over a year now, and it's always run fine, until a few days ago. I started it, and it started, then immediately shut off. Tried again, same problem. I was able to use the throttle to hold it over 2k rpm's and it didn't shut off then. Driving the car was interesting, as it would have periods of running fine, then it would start misfiring, and occasionally just stop firing altogether. I'd have to put it in neutral and start it again.
    The next day, drove it to work, and it ran with no issues. On the way home, the problem came up again. It's been happening on and off ever since. Here's what I know.
    It began 4 miles into a fresh tank of gas.
    The engine is throwing the following codes:
    P0128 - Coolant temp is always low
    P0440 - EVAP small leak/no flow condition
    P1810 - Transmission Pressure (TFP) switch manifold fault
    P0135 - H02S11 heater condition
    P0420 - Catalyst Efficiency low - bank 1
    P0300 - Cylinder Misfire detected - random cylinders
    P1133 - Heated Oxygen Sensor - bank 1 sensor 1 insufficient switching
    It's a 2002 GP GT with 140k miles.
    Any ideas where I should start?
    Edit:Title (03->02)
  2. #2 Re: 03 Grand Prix Constantly Misfires
    GXP Level Member
    Mar 2015
    Tomball
    How old are the plugs and wires?
  3. #3 Re: 03 Grand Prix Constantly Misfires
    Jun 2014
    Nappanee, IN
    No idea. I haven't changed them.
    Would this happen with plug wires? All pistons are misfiring, right?
  4. #4 Re: 03 Grand Prix Constantly Misfires
    GXP Level Member
    Mar 2015
    Tomball
    I think it could cause a few of those codes. Change the plugs and wires first use iridium if you want them to last a long time and copper if you don't mind changing them every 10k or so. Use the house brand plug wires (autozone/advance/ o'rileys/ whatever). Start with that.
    Jeff
  5. #5 Re: 03 Grand Prix Constantly Misfires
    Jun 2014
    Nappanee, IN
    Okay, I can change the plugs/wires tonight. I should mention that this doesn't seem to be a single piston or even two pistons misfiring, often times it feels like I'm running on only one or two pistons (Can't maintain 30 mph with pedal to floor). Sometimes it revs, cuts power, then kicks in again momentarily, sometimes it runs with no power, then sometimes it'll drive fine for 1/4 - 1/2 mile then start acting up again. I believe the most odd thing is the fact that I haven't had any issues with the car when first driving it in the morning (around 8:00). It drives like normal then, but it misfires at all other times. Another thing, I'm getting 12 MPG.
  6. #6 Re: 03 Grand Prix Constantly Misfires
    GXP Level Member
    Mar 2015
    Tomball
    I think someone else should chime in, but if it runs IC cool then maybe the ICM's connections need to be cleaned. Could be a partially clogged cat. Check the wiring going to the O2 sensor it may be damaged causing the O2 codes. the 1810 I am not sure about, it's an 03 so I wouldn't figure it would be like a vacuum operated modulator, but I am not sure on that car. The misfire on random cylinder code is probably just bad plugs and wires.
    Lets get the checking and plugs /wires out of the way first.
  7. #7 Re: 03 Grand Prix Constantly Misfires
    I would personally fix the fueling issue (swap out front O2 sensor and coolant sensor). Those two are hosing your fueling horribly, likely causing the misfires.
  8. #8 Re: 03 Grand Prix Constantly Misfires
    Jun 2014
    Nappanee, IN
    Both sensors have under 5k miles on them, I just recently changed them. I cleared the codes when I installed them. Are there two coolant sensors? I only changed the one that I found (near the thermostat, which I also changed. Also, couldn't the O2 sensor be having issues due to the misfiring?
  9. #9 Re: 03 Grand Prix Constantly Misfires
    There is only one coolant sensor.
    If you changed both and the codes came back, check fuses to the O2 and wiring to the coolant sensor.
  10. #10 Re: 02 Grand Prix Constantly Misfires
    Jun 2014
    Nappanee, IN
    J57ltr, It's a 2002 GP, I get confused sometimes because my last car was a 2003 GA.
    BillBoost, should the gauge work if the sensor doesn't? It reads the correct temp.
  11. #11 Re: 02 Grand Prix Constantly Misfires
    There are two sensors built into the one item. One feeds the PCM (hence the code) and the other feeds the dash. This explains why you see the right temp, but the pcm is complaining.
  12. #12 Re: 02 Grand Prix Constantly Misfires
    Jun 2014
    Nappanee, IN
    While checking for vacuum leaks, I bumped the cord for the Mass Air Flow sensor. It began running smoothly, so I unplugged it. I'm getting a new MAF sensor tomorrow, hopefully that will clear things up.
  13. #13 Re: 02 Grand Prix Constantly Misfires
    check the wires to the maf plug. if you see cracks or bare wire showing the pig tail is bad and needs a new one.
    if the wires are good. maf plugged in, car running, tap the top of the maf, see if it runs better, then bad again when tapped on.
  14. #14 Re: 02 Grand Prix Constantly Misfires
    oh, and dont get a aftermarket maf, they suck in our cars, you want a oem maf. aka junk yards are cheap. used on e bay too. 40 tops most of the time.
  15. #15 Re: 02 Grand Prix Constantly Misfires
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    i believe amazon has hitachi mafs for about 80 bucks...don't hitachi make them for gm ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  16. #16 Re: 02 Grand Prix Constantly Misfires
    Mar 2012
    NC
    No one has mentioned this might be a plugged cat? Remove the front o2 sensor from the exhaust and try driving it. It'll be loud but if you have your power back, there's your issue.
  17. #17 Re: 02 Grand Prix Constantly Misfires
    Enfield, CT
    Dude I put a brand new Delphi MAF in my 97 and it was fantastic.
    Yes Hitachi was the OEM supplier but I wouldn't be surprised if their quality went down the sh!tree.
    Sent from my LG G3
  18. #18 Re: 02 Grand Prix Constantly Misfires
    Jun 2014
    Nappanee, IN
    Okay, so a lot of differing opinions here. I don't have a ton of money (broke college student), but Napa carries them re-manufactured for $135. I can afford this, but this price tag is more appealing:
    http://www.amazon.com/Hitachi-MAF004...ype=automotive
    I don't want to half-a$$ this, what is my best bet? I got the current MAF from a junkyard about a year ago.
  19. #19 Re: 02 Grand Prix Constantly Misfires
    top of your maf is the part # search that # in ebay for a used oem maf. 40 bucks tops most of the time, or less.
    or hit a junk yard near by and snag one there. im running a jy maf for the last 5 years now. best 40 bucks spent. the maf can come out of a na or a sc car. same part #.
    you need to find a car thats a 01-03 iirc double check the part # before buying one.
  20. #20 Re: 02 Grand Prix Constantly Misfires
    Mar 2012
    NC
    I feel my free diagnostic suggestion is going unnoticed...
  1. Constantly use performance shift?
    By firstgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2015, 11:01 AM
  2. Constantly needing new CV axles
    By Dtrick22 in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2012, 06:04 AM
  3. signal light clicking constantly
    By Donna Lee in forum General Tech Discussion
    Last Post: 05-29-2011, 11:30 AM
  4. Car Constantly Pops MAF fuse
    By Lethaface in forum General Tech Discussion
    Last Post: 04-18-2009, 08:03 PM
