I have an 07 gp na, when i get the rpms around 5k, the engine shuts down as if you turn the key off. It does this under load or if it is in neutral. I can start it right after it dies. I have checked all the wiring, redid the grounds and power wires, replaced the maf, cleaned throttle body. It runs great untill 5k. Had a scan tool hooked up to it, when it dies the tool loses connection with the pcm. Any ideas?
