Thread: Loosing Gas
Results 1 to 8 of 8
  1. #1 Loosing Gas
    Chicago, IL
    So I usually get about 380 miles for a full tank and lately I have been getting about 250 for a full tank. Most of my mileage is highway too. What reasons could gas be getting cut down so badly?
    MSD Ignition Coils, K&N CAI, SLP Headers/Downpipe/High Flo Cat/Cat Back Exhaust, Overkill PCM, 20" Moda Rims
  2. #2 Re: Loosing Gas
    Jul 2008
    nj
    Have you done anything to your car since the last time you got 380 miles to your tank? I can think that the cold weather might be playing a role here, but I can not see a loss of 100 miles. Are you letting your car idle to warm up? Is your trans really cold when you are on the highway? My tcc does not lock up until the trans temps are around 100*F
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  3. #3 Re: Loosing Gas
    SE Level Member NME's Avatar
    how many miles are on your car? could be an O2 senser
    9" k&n Cone - N* - DOHCZ34 Ported Gen V - ported LIM - XP cam - 90# springs - 3.3 mps -Wraped pacesetter headers - Fuel rewire - waiting on new IC's!
  4. #4 Re: Loosing Gas
    Charles City, IA
    I would say cold weather is the culprit.
    SMGPFC Two Nipple General
  5. #5 Re: Loosing Gas
    Nov 2008
    Searcy,Arkansas
    Also if your air in your tires are messed up it will take away your gas! Or check your airbox/filter and make sure everything is clean. I never heard of 100mpg loss...butttt those are just some things to check.
  6. #6 Re: Loosing Gas
    Dec 2008
    Florida
    My car has done the same things. I am now getting around 13-14 mpg in town instead of 18-22. An 02 sensor could be the culprit? The car is stock and has had a tune up done on it. Also I recently had the lower intake manifold gaskets done at the stealership.
    2000 Pontiac Grand Prix GTP
    I love my 5.0, but a little civilized muscle is a good thing! Especially when it always runs and doesn't leave you stranded on the highway.....
  7. #7 Re: Loosing Gas
    Feb 2009
    st cloud
    Fuel pressure regulator. pull the vacuum line off the top of it while motor hot and running, check for fuel smell inside port, or wet gas dripping out of line.
  8. #8 Re: Loosing Gas
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Interested to see what comes up out of this. I have been noticing the same problem. Mine is a bit better after replacing the maf due to other issues, but I don't know if it's just the cold weather bringing my milage down so much.
