Thread: HV3 Knowledge - Let's learn something
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41 Re: HV3 Knowledge - Let's learn something
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    The difference between an L26 and L36 is the extra notch (i believe for the PCV system) on the side. The L36 has it and the L26 does not. I'll take a pic of my L26 in my attic when I get home. I do know mine is red.
    97 Bonneville SE Not so much a 97 anymore
  2. #42 Re: HV3 Knowledge - Let's learn something
    Enfield, CT
    Quote Originally Posted by Nighthwk12 View Post
    Well if you look at the picture, especially the first one, you'll see the sides are a little skinnier
  3. #43 Re: HV3 Knowledge - Let's learn something
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Where's the how to do it yourself thread bill you make one yet?
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #44 Re: HV3 Knowledge - Let's learn something
    Quote Originally Posted by Travisgt2 View Post
    You hack the top of the runners off.
    Glue them back together after cutting them down to an inch or so in height.
    The end.
  5. #45 Re: HV3 Knowledge - Let's learn something
    Jan 2013
    leavenworth ks
    Oh okay thanks blue. blue you stilt in the kc area?
  6. #46 Re: HV3 Knowledge - Let's learn something
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Could someone make a write up for those (like myself) that are not confident enough to do something like this without some direction?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  7. #47 Re: HV3 Knowledge - Let's learn something
    Dec 2012
    Where 4T65E's were born
    Yeah, I just looked at one I have sitting in my garage, and "gluing it back" has me confused lol.
    Sold.
  8. #48 Re: HV3 Knowledge - Let's learn something
    Jul 2012
    Chicago
    You just need to remove some runner material, thereby decreasing their height. Take the tops and glue them back onto the bottom of the runner piece. And boom, custom HV3.
    -Carl
  9. #49 Re: HV3 Knowledge - Let's learn something
    May 2008
    Winnipeg, MB
    Should I take my HV3 out and sell it?
    2007 Pontiac Grand Prix
  10. #50 Re: HV3 Knowledge - Let's learn something
    Enfield, CT
    Quote Originally Posted by tod1d View Post
    Well you already paid for it and went through the work so just leave it in there until you are ready to move on
  11. #51 Re: HV3 Knowledge - Let's learn something
    I wouldn't get rid of one if I had one...
    But I'd also not go out of my way to buy one either.
  12. #52 Re: HV3 Knowledge - Let's learn something
    Dec 2014
    Austin, TX
    Quote Originally Posted by blueguy View Post
    Probably just a different mold.
    I can't see rounded vs angled edging making a ****s lick of difference on a manifold style like that anyways. I ran no insert in my GT, a DIY HV3, and the L26 HV3 in my L26 UIM setup.
    I noticed no difference between the DIY to the ZZP version...and I honestly noticed only a smidge better top end by putting the insert in there vs. not even running one.
    DIY hv3? youve got my undivided attention mate.
  13. #53 Re: HV3 Knowledge - Let's learn something
    Dec 2014
    Austin, TX
    nvm. ill read the rest of the thread first next time
  14. #54 Re: HV3 Knowledge - Let's learn something
    Dec 2012
    Still wasn't explained lol
    Sold.
  15. #55 Re: HV3 Knowledge - Let's learn something
    Enfield, CT
    LOL
  16. #56 Re: HV3 Knowledge - Let's learn something
    Jul 2012
    Chicago
    What hasn't been explained?
    -Carl
  17. #57 Re: HV3 Knowledge - Let's learn something
    Dec 2012
    Well I can hack 1 inch off the top. ok and done? Won't it sit too far up in the intake now?
    And this I don't understand
    The end.
    So cut the piece off and glue it back? lol
    Sold.
  18. #58 Re: HV3 Knowledge - Let's learn something
    Jul 2012
    Chicago
    When you cut off the runners, you trim them down so they are shorter. Then glue the shorter pieces back on.
    -Carl
  19. #59 Re: HV3 Knowledge - Let's learn something
    Enfield, CT
    So I was just browsing for something on ZZP and happened to see that the HV3 is now $150 instead of $200. Crazy
  20. #60 Re: HV3 Knowledge - Let's learn something
    Buffalo, NY
    I don't understand the gluing part. To make my own I will have to glue something I'm putting back in my engine?
  1. Kid with some knowledge and 2 cars
    By vtechkiller in forum Introductions/Noob Questions
    Last Post: 08-25-2012, 06:05 PM
  2. Here to gain knowledge from you!
    By GoGoGirl in forum Introductions/Noob Questions
    Last Post: 06-21-2011, 11:15 AM
  3. Need some e85 knowledge
    By GAFF in forum Off Topic Discussion
    Last Post: 11-21-2010, 08:48 PM
  4. Anyone have knowledge on Alero's
    By Mikefisher in forum Off Topic Discussion
    Last Post: 10-29-2008, 01:18 AM
  5. For My Knowledge Really...
    By blueguy in forum PCM Tuning
    Last Post: 09-12-2008, 12:15 AM
