Thread: What scanners can delete rear o2 code?
Results 1 to 5 of 5
  1. #1 What scanners can delete rear o2 code?
    Jul 2014
    Phoenix, AZ
    My hi flow.cat just burnt up my downstream o2. Im going to put the o2 on a extender from ebay. Or can i just delete the codes for the rear o2 altogether with also leaving the old burnt o2 on the downpipe? What scanners can delete the code not clear. Thx!
  2. #2 Re: What scanners can delete rear o2 code?
    dhp or htp tuners work on our cars.
    you best to just find a local to delete your codes. theres others out in your state, no idea if they have a tuner or not.
    then you could always ship the pcm to someone to delete the code and then they ship the pcm back codes deleted.
    i could do this ^^^ if you want. i could add bills trans tune to it too. you either find another pcm from a junk yard same year car and ship that one, or ship yours and be with out a car for a while.
    id need your vin# too if you get a spare pcm to tune, as you need to pass inspection and the vin needs to be changed in the new pcm to your cars vin #. or you'll fail inspection.
    the shipping will be the killer really, its like 15 each way. if not more, your further then most around here lol
  3. #3 Re: What scanners can delete rear o2 code?
    The high flow didnt didn't burn ANYTHING up, it didn't literally melt down inside.
    All it did was throw a code saying the cat converter flows too well for what the car is suppose to see.
    Clear the code with a handheld scanner and space the rear o2 further away, that should fix the issue.
  4. #4 Re: What scanners can delete rear o2 code?
    Jul 2014
    Phoenix, AZ
    The code was a Po141. Not a Po420, But I think I will just get new sensors since I got a code for the downstream o2 sayin it was bad. What do you think? I ordered a o2 extender from ebay too.
  5. #5 Re: What scanners can delete rear o2 code?
    the fouler should work, and its cheap. so if the rear o2 code has not shown its self let it go till it does.
    and that code is for the up stream o2, http://www.obd-codes.com/p0141 its basically saying the heater in the o2 is not working. this is the o2 thats blocking the spark plug on the back of the engine. you need a o2 socket to remove it.
  1. Replies: 8
    Last Post: 06-28-2013, 01:22 PM
  2. EGR Code delete using torque pro
    By Beelzeboul in forum PCM Tuning
    Last Post: 08-18-2012, 04:47 PM
  3. Delete EVAP code
    By Deathsports in forum PCM Tuning
    Last Post: 11-09-2010, 04:17 PM
  4. If i delete the rear 02sensor code(p0420)
    By kinglou10 in forum PCM Tuning
    Last Post: 07-02-2009, 05:22 PM
  5. scanners ??????
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2008, 02:49 PM
