Thread: '02 Grand Prix P0171 after MAF replacement
Results 1 to 10 of 10
  1. #1 '02 Grand Prix P0171 after MAF replacement
    Sep 2014
    New Hampshire
    Hey guys,
    I'm new here so forgive me if I've missed something obvious. I have googled this and I haven't found any answers (yet) that apply or that I haven't tried already.
    First, some history. My girlfriend has a 2002 Pontiac Grand Prix GT, completely stock 3800 series engine, automatic transmission. It's got almost 130k miles on it and over the past few years we've owned it, we've put a lot of work into it. Recently we broke down; left a restaurant and couldn't start the car. It would crank and crank but would only run for a second and then die. We were desperate and cranked it to the point of it starting to smell like rotten eggs due to rich fuel mixture.
    After some googling on my phone, I found a website where someone suggested pulling the connector off the mass airflow sensor and trying to drive without it connected. I did this a we were able to start and drive the car to the nearest auto parts store! The check engine light triggered but we were no longer stranded. I read the code later and it was the code for having the MAF circuit open; I don't recall the exact number. I changed the MAF in the parking lot and afterward we were able to start the car and it would stay running this time instead of dying right away. The CEL went away (but the code was still in the computer) The idle was now rough, whereas before the breakdown there were no problems with the idle, but other than that, we were relieved to be able to drive the car around reliably. It seemed a little odd that the idle was rough but it drove fine, didn't hesitate, had plenty of power. I chalked the rough idle up to the computer needing to re-learn after having the MAF replaced, and I figured it would go away after enough time / miles had gone by.
    About a week later we took the car in to get it inspected. We live in New Hampshire and we have emissions tests. At the same time, we had the air conditioning condenser and dryer replaced, since the condenser had developed a leak. The technician opened the coolant lines etc to get radiator out of the way to do the A/C work. When the work was completed, the tech found we had a new code: P0171 He performed a re-learn using his scan tool but the code came back. He replaced the upstream oxygen sensor and put a new fuel filter in; no change. He measured the battery voltage and found that one of the terminals was green and the battery was only measuring 10 volts... he cleaned the terminal and we got a replacement battery but the P0171 code has come back... that's a re-cap of the last two weeks. We just can't get this code to go away.
    Interestingly enough, the idle had gotten worse at this point, and a couple times the car had stalled and had to be re-started; but not like the original MAF issue (where the car was absolutely not staying running when the MAF was bad). Under load (A/C compressor on; brake depressed and in-gear, drive or reverse) the idle cleans up. In park or neutral, the idle was kind of rough and the engine would vibrate. The replacement battery seemed to help the idle, it's still not perfect, but a lot better. However, the P0171 remains.
    I'm at a loss. I feel like we have checked almost EVERYTHING and we still can't get the P0171 to go away. At this point we can't get an inspection sticker because of this problem and we've been waiting more than two weeks to get the computer to return clean codes so we can get an inspection sticker.
    Here's a list of things that have been replaced that might be relevant to the P0171. I am CONSTANTLY fighting CELs on this vehicle. I am open to the possibility that some of these "new" parts might be bad but I just don't know where to start (or re-start) and I would be very grateful for some guidance.
    - In the last year: replaced the fuel sender unit, gas gauge didn't work, also replaced the fuel pump at the same time
    - In the last year: mufflers replaced due to rust
    - In the last year: secondary air injection pump replaced due to code
    - In the last year: air filter replaced for routine maintenance
    - In the last 8 months: cat-back exhaust (not incl. cat) replaced due to rust
    - In the last 8 months: throttle body cleaned due to sticky throttle; IAC pin is clean
    - In the last 8 months: thermostat replaced due to poor heat
    - In the last 8 months: coolant temperature sensor replaced, also related to poor heat, temperature gauge didn't seem to read correctly even after thermostat replacement, gas milage improved after replacement
    - In the last 6 months: downstream O2 sensor was replaced (code for downstream O2 heater circuit, tested bad with a multimeter and replaced, code went away)
    - In the last 6 months: catalytic converter replaced (code for catalyst efficiency; checked for and repaired exhaust leaks but didn't resolve; replaced catalytic converter and code went away)
    - In the last month: MAF replaced due to apparent malfunction
    - In the last week: Checked PCV valve, checked MAP sensor seals
    - In the last week: smoke tested for vacuum leaks, none found
    - Checked the vacuum line on the fuel pressure regulator for fuel seepage; none found
    - In the last week: upstream O2 sensor replaced in an attempt to fix P0171
    - In the last week: fuel filter replaced in an attempt to fix P0171 (and it was due for replacement)
    - In the last week: battery replaced when it was discovered the original was only 10V, probably dead cell
    - In the last week: the computer has been reset multiple times; codes cleared and a "re-learn" performed by the tech using his scan tool
    The only thing I can think of to have them do next is a fuel pressure test? Maybe we have a bad fuel filter or the less-than-1-year-old fuel pump is weak? Fuel pressure regulator bad? I think the only sensor we haven't replaced is the MAP sensor, and perhaps the intake air temperature sensor. I read that the P0171 is triggered when there is a 20% discrepancy in compensating for the air-fuel ratio, that seems like a lot, so how is this cause and solution not obvious??
    I appreciate any input anyone can provide. Thanks in advance.
  2. #2 Re: '02 Grand Prix P0171 after MAF replacement
    What brand MAF sensor did you buy??
    Store brand or non AC delco parts are known to giving people problems. It's possible the new MAF is the cause seeing how you have already tested it for a vacuum leak, which is exactly what that code is for.
    Maybe the new MAF sensor isnt seated all the way inside the throttle body too, but now I'm just throwing guesses out there.
  3. #3 Re: '02 Grand Prix P0171 after MAF replacement
    Sep 2014
    New Hampshire
    Hmmm... well that's bad news. The MAF was like >$200 and they told me there is no return on electrical parts once installed (but at the same time there is a manufacturer warranty against defects for 1 year or something?)!
    The MAF is not AC Delco, unfortunately. The nearest auto parts store we limped to was Bond (a chain in New England), sold us a "Standard Motor Products" model number MF5288, which can be seen here: http://www.amazon.com/Standard-Motor.../dp/B000CKRJ16 - not that this tells you much...
    The MAF seems flush to the throttle body, I can't get so much as a fingernail between the two. The screws are reasonably tight... not sure what else I could've done wrong
  4. #4 Re: '02 Grand Prix P0171 after MAF replacement
    hit a junk yard, used mafs run 40 bucks, have a warranty believe it or not lol
    or used off ebay, search the part number on the top of your stock maf.
    your maf is used in more then just grand prix, so if you have a junk yard check all the gm cars for your part #. cars with in a year or two of yours.
  5. #5 Re: '02 Grand Prix P0171 after MAF replacement
    Sep 2014
    New Hampshire
    Yikes, good call. I checked eBay and they're like $40 - $50. So far the consensus is that the MAF I bought is toast? That's pretty disconcerting. I should see if I can get any of my money back if that indeed proves to be the case. For $40... and I can stop beating my head against the wall? SOLD!
    Thanks for the input thus car, greatly appreciated.
  6. #6 Re: '02 Grand Prix P0171 after MAF replacement
    yeah, them aftermarket mafs suck.
    im on a jy maf thats 5 years old now, it came out of a n/a park ave, im supercharged, same part #.
  7. #7 Re: '02 Grand Prix P0171 after MAF replacement
    Jul 2013
    Richmond, VA
    Not sure if they changed between 02 and 07 but I just bought this one.
    ACDelco 213-1677 GM Original Equipment Mass Air Flow Sensor by ACDelco http://www.amazon.com/dp/B000EQP9JC/..._yRmiub0W1HAKC
  8. #8 Re: '02 Grand Prix P0171 after MAF replacement
    Holy ****, 27 bucks LOL.
    HUGE discount, but thats not right for his car. 97-98 are special to those years. 99-03 have there own MAF and 04-08 have a different style MAF aswell, like that one you posted.
  9. #9 Re: '02 Grand Prix P0171 after MAF replacement
    Sep 2014
    New Hampshire
    Based on your suggestions, I ended up replacing the MAF with one from eBay, an A/C Delco 213-4337 for $167.81. Cleared the codes and emissions tests, drove around for about a week, and finally got everything to pass. The P0171 never came back. We finally got an inspection sticker. What a painful experience!! I am so glad it's over.
    The one that the car rejected was a Standard Motor Products MF5288. I highly recommend AVOIDING this MAF!
    Now to see if I can get my $200 back for the MF5288 :-(
    Thanks again everyone for your help. I was at my wit's end!
  10. #10 Re: '02 Grand Prix P0171 after MAF replacement
    glad to see your set now.
    if you try to return it, clean it up so it dont look like it was installed. they wont take back most electrical parts as it is. but if its been installed they really wont take back at all. so lie a little bit if need be.
  1. Looking for a replacement on the Grand Prix
    By elhomero in forum General Grand Prix Discussion
    Last Post: 07-17-2014, 04:23 PM
  2. Grand Prix air bag replacement
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-04-2014, 05:07 PM
  3. grand prix gxp rim replacement
    By DirtDog in forum Tires & Wheels
    Last Post: 12-27-2012, 11:36 PM
  4. 00 Grand Prix Cat Replacement
    By orange57 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-22-2012, 03:04 PM
  5. Grand Prix Door Replacement
    By donwan in forum General Tech Discussion
    Last Post: 06-12-2011, 11:01 PM
