Thread: where to find L36 engine in Atlanta area
Results 1 to 16 of 16
  1. #1 where to find L36 engine in Atlanta area
    May 2014
    Georgia
    So I just got a 97 grand Prix gt. It has 240000 miles on it. So I go get a tune up. On the way back, about five miles, it starts knocking and dying and I barely make it the last quarter mile or so. So now I have it just sitting there. I expect it to need replacing the engine and transmission. I was hoping to get more than twenty miles out of it.
    Then today my cousin comes over and we are looking at it. He says start it, so I do. Immediately, he says kill it. Says there is a dropped rod, I think. He pulls the oil dipstick out and says "Jesus, it is way over full. Says we over filled it and it now something has to be rebuilt.
    Now, I was there during the tune up. I handed him the oil. We did not overfill it. Could there have been a bunch that didn't drain?
    So now I am looking for a low mileage engine in the north Georgia area. Transmission as well probably.
    Any idea's?
  2. #2 Re: where to find L36 engine in Atlanta area
    Perhaps the intake gasket failed and filled the crankcase with coolant, and thats why it's overfilled.
    Tried carpart for motors yet?
  3. #3 Re: where to find L36 engine in Atlanta area
    Try car-part.com you could also search for an engine out of a 2005 gp you will have to change the upper intake, tb, and oil pan or cut the lower engine mount bracket so it will go around the oil pan.
  4. #4 Re: where to find L36 engine in Atlanta area
    May 2014
    Georgia
    Checking car parts now. When it started acting up, it gave a check engine light. We hooked it up, it said number two was missing. We pulled the plug and it was drippng oil.
  5. #5 Re: where to find L36 engine in Atlanta area
    Toasted piston most likely.
  6. #6 Re: where to find L36 engine in Atlanta area
    May 2014
    Georgia
    Is there a thread that list the engines you can use in this model?
  7. #7 Re: where to find L36 engine in Atlanta area
    97-04 regals
    97-03 grand prix
    96 or 97+ to 05 bonneville
    park ave had it from like 99+?
    00-05 monte carlo
    00-05 impala
    All those cars ran the L36 motor.
  8. #8 Re: where to find L36 engine in Atlanta area
    And like I said you can also run a L26 just need to change out a few things, and it will most likely be cheaper and have less miles than a L36.
    L26 was in
    2004-2008 Grand Prix
    2005-2009 Buick Lacrosse
    2006-2008 Buick Lunerne
    Cam Park Avenue had the L36 from 95-05 or whenever they stopped making them. Same with the Bonneville iirc.
    From Wikipedia
    This engine was used in the following vehicles:
  9. #9 Re: where to find L36 engine in Atlanta area
    May 2014
    Georgia
    Thank you. I guess I an going to look for one of these locally and see what we got.
  10. #10 Re: where to find L36 engine in Atlanta area
    May 2014
    Georgia
    So can I put a supercharged 3800 in the regular GT body?
  11. #11 Re: where to find L36 engine in Atlanta area
    you can. but you'll want to get your pcm tuned for it. and re wire a few little sensors. very doable.
    and you can bolt it right up to your tranny too. may have to swap the flex plate but that no big deal.
  12. #12 Re: where to find L36 engine in Atlanta area
    May 2014
    Georgia
    I found a couple 3800s on craigslist, but then I seen the supercharged and said hmmm
  13. #13 Re: where to find L36 engine in Atlanta area
    it will cost you about 100 bucks more for a canned tuned pcm from a vendor.
  14. #14 Re: where to find L36 engine in Atlanta area
    May 2014
    Georgia
    I hate to clutter up this thread so much... But I do appreciate youse guys opinions. So I am looking at two 3800s on craigslist. One had 75 grand miles and the other is 117 grand I think. Both are near $400. My question is how can I tell if they are any good. What I mean to say is what can I look ffor beyond what they tell me. Any ideas?
  15. #15 Re: where to find L36 engine in Atlanta area
    pop a valve cover off to see the rockers, if they are caked with burnt oil and black you may not want that one. check the oil to see if its just oil. ( black rockers means they didnt change the oil regularly)
    if its not in the car any more and you cant hear it run or drive it first. you can do a compression test on the cylinders before you buy it.
    id go check the lower miles one first. there not that far a part, but lower is better.
  16. #16 Re: where to find L36 engine in Atlanta area
    I just pull a valve cover and look in. No need to pull the cover IMO. Takes too long..lol
  1. GPs In the Atlanta area
    By Kasey in forum Southeast
    Last Post: 07-28-2016, 11:46 AM
  2. Replies: 5
    Last Post: 09-23-2014, 08:49 PM
  3. Looking for a decent mechanic in the Atlanta area
    By Magda in forum General Grand Prix Discussion
    Last Post: 09-16-2013, 10:58 PM
  4. Anyone Tune in the Atlanta, GA area?
    By ddyke2000 in forum PCM Tuning
    Last Post: 05-31-2010, 05:37 PM
