You didn't check the flexplate for cracks did you?
K i'm rather sure its not a rod..... the car from a cold start takes around 5 mins to start the knock(if it was a rod it would be almost instant imo)...in the vid i posted the car only cooled for about an hr. That being said I did remove the plastic inspection plate to see the flywheel althou you cant see all of the flywheel, but I didn't see any visible cracks from what I could see. It did "wobble" slightly thou.
Sounds like exactly what mine is doing. The engine has to warm up before it has any problems. Very interested in seeing what the issue ends up being.
Wow, I didn't even pay attention to the year. Thanks for the heads up lol
