I just talked to a guy on CL who is parting out his L36.
He's asking $15 for the TB spacer.
Yea? Nay?
Yea? Nay?
Ask yourself what value it would add when your pcm corrects for intake temps and being an L36 you have a plastic UIM which shouldn't heat soak much. Your heat soak is going to be from the TB being under the hood.
Now..if you wanna cause a coolant leak, potentially into the intake....then I'd suggest installing it.
Only worth it if you're going to spray
Okay, not getting it. =)
