I have a 2006 that has just rolled over 250,000 miles, the water pump was replaced by me at 225,000.
Long story short, car starts to get hot, is leaking coolant, too fast to limp it home, I meet the wrecker with new hoses for the radiator, upper and lower (originals with 250K were on it), after replacement I still have a leak.
The car has a coolant leak from underneath the water pump.
I thought after seeing this leak that the water pump must mount on a manifold that bolted to the timing chain cover, and it needed a new gasket.
I jump into my alldata account to investigate the repair and I see that the water pump mounts to the timing chain cover and there is no gasket where the coolant spews from under pressure. It is coming out from what must be a stress fracture or crack on the middle of the timing chain cover right under where the right side of the water pump is. I removed the pump and got my mirror and a bright light and I can see the red area where it is coming from.
Anybody else seen a timing chain cover do this?
I will put up pics after I finish getting it off the car tomorrow.
I found a replacement at JC Whitney for 119.00, any other places I could check for a replacement timing chain cover besides the expensive dealer part?
I will put a new chain on it while I am in there obviously, anything else I should pay attention to while I have that open?
Thanks in advance
