Thread: oil leak
Results 1 to 12 of 12
  1. #1 oil leak
    Illionis
    Ive got a 2008 GP base, it has about 196000 on it now and on Friday night i took a bit of a road trip, then about half way thru the trip i noticed smoke coming out of the back of my car. I thought i was burning oil but no i sprung a damn leak. The whole front side of the engine is soaked in oil and I had to go thru five qts to get home. So today I was doing some looking around with a can of break clean and i noticed that the drops of oil were falling from around the crank pulley, but i am not for sure. So my question is how common is it for a crank case seal to leak, and i need more ideas on where to look.
    Thank in advanced for any info.
  2. #2 Re: oil leak
    I'd take a bet and say its coming from the oil pressure sendor which is right behind that area.
    Though the front seal can go, but its not as commom.
    Try cleaning it up better with some de-greaser and then let it dry and then start the car and see where the dips are coming from.
  3. #3 Re: oil leak
    if you turn the wheels all the way to the left, then stick your head behind the pass side tire, look at the oil filter, now just past it is the oil pressure sensor, start the car watch the pressure sensor for oil to pour out of the plug.
  4. #4 Re: oil leak
    Banned
    Oct 2013
    Moorhead, MN
  5. #5 Re: oil leak
    Banned
    Oct 2013
    Moorhead, MN
    Sorry, that's a 2000 3.8 GT but you get the idea.
  6. #6 Re: oil leak
    St. Louis
    And on the diagram its item 442 from what I can tell.
  7. #7 Re: oil leak
    Banned
    Oct 2013
    Moorhead, MN
    Or the gasket. I have an extra if anyone needs.
  8. #8 Re: oil leak
    There's really very little in that area to leak. Like the guys said, the crank seal, the pressure sender or the filter/adapter gasket.
  9. #9 Re: oil leak
    Illionis
    Hey thanks alot for all the good info but last night i did some looking around on a buddys lift and found the damn leak. Just so happened that it really did come out to be the front main seal. Now, I have heard that to cause that it is improper venting of crank case pressure, what do you guys think? I do however have a cai and a hv3 but i dont think that would make any difference. Again, what do you guys think?
  10. #10 Re: oil leak
    SE Level Member stockGTforlife's Avatar
    Aug 2013
    Alliance, Ohio
    oh god...i have the same exact mods, hope that doesnt happen to me haha
    97 Grand Prix GT- Will be missed...
    04 Monte Carlo Supercharged SS- Bone stock.....for now
  11. #11 Re: oil leak
    Illionis
    it just turned over 196000 today so i really think its the mileage that did it
  12. #12 Re: oil leak
    Banned
    Oct 2013
    Moorhead, MN
    I'm thinking the 196,000 may have done it. Lol
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
