Thread: I need your Engine Bay pics!
Results 1 to 20 of 20
  1. #1 I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    I'm at a standstill with some final connections and wire routing on my engine rebuild.
    Could you email me some of your detailed engine bay pics? Any help is appreciated.
    thompsju@outlook.com
    Thanks in advance!
    -Justin
  2. #2 Re: I need your Engine Bay pics!
    antioch ill
    there is a thread on here for all of this.
  3. #3 Re: I need your Engine Bay pics!
    antioch ill
  4. #4 Re: I need your Engine Bay pics!
    Help me help you.
    Show me what you still need to connect and I (we) can tell you where they go.
  5. #5 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    Those aren't detailed. I'm looking for sections.
    I'm not supercharged. There are significant routing differences.
    Here's where I'm at.
    For starters, spark plug routing. All mine are pulled out.
    ( 2 o'clock) There's a cluster of connections that come out from the firewall by the by the master cylinder/vacuum booster.
  6. #6 Re: I need your Engine Bay pics!
    A better picture of the cluster of connectors will help.
    Here is a picture of the spark plug wires, it does not matter that this engine is supercharged as its all the same.
  7. #7 Re: I need your Engine Bay pics!
    And what did you paint the exhaust with??
    I sure hope its header paint or something, or else it'll just melt and burn off.
  8. #8 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    High temp paint. :-)
  9. #9 Re: I need your Engine Bay pics!
    Arizona
    Quote Originally Posted by Thompsju View Post
    Hope you baked that crossover in the oven first. And let it cure or else it will bubble up. And flake off and look like ****. Those connections look like they go to your transmission . the round OnE should go to the top of the trans and the other to the rear were your shift cable goes.
    That ground connects to the trans on the front side iirc
  10. #10 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    Hmm... Sounds like 91 is on the right track. The ground bolts into the frame under the cruise control bracket.
    There are 2 or 3 others, including a round plug in. I'm lost on those, and it's too freaking cold to go outside atm.
    Also... ;-)
    I got yelled at. LOL
  11. #11 Re: I need your Engine Bay pics!
    Portland Oregon
    I can see where the connectors plug in. They're literally inches from their counter parts in your second pic. Round into the round one and flat one into the flat one.
  12. #12 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    Could someone go out to their car and just tell me where that harness runs? Lol
  13. #13 Re: I need your Engine Bay pics!
    Arizona
    Did you look on top of the trans where I mentioned? Whats not hooked up? You'd have to remove the airbox to see what I was referring to.
  14. #14 Re: I need your Engine Bay pics!
    That blob you pulled up by the airbox, runs along the frame at and to the trans (big round plug) any little plugs on it should fall to the park neutral switch, the eyelets bolt on the lowest and frontmost transmission stud with the battery negative cable via a 15mm nut.
    The other side, the wire you have by the rad cap, goes to the back and behind the coils, runs down the motor to the crank and cam sensors. You are the man with all the diagrams in all your other threads, where's the ones on electrical routing?
    If you want detail..
    Photobucket.com
    Username: BillBoost37
    Password: Boosted (capitalize the b and only the b)
    There's more detail of more stuff than you'll ever be able to use. I'd suggest writing a note to your wife and packing a lunch/dinner before you log in.
  15. #15 Re: I need your Engine Bay pics!
    PS.. I didn't need to go to my car. I could describe the routing to you in detail,....like the arrow on the big gray plug faces straight up (doesn't point up) and it'll slide right onto the main trans connection right on the upper driverside of the trans.
    I'd also suggest that you take detailed pictures before pulling something apart if you aren't 100% sure of where things go. It works great when I'm doing something different/new.
  16. #16 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    I've got the engine Harness covered, just had to remove the ice to route the engine harness around the radiator hose.
    K, I'll take the air box out and start digging, unless removing the driver side wheel would be easier?
  17. #17 Re: I need your Engine Bay pics!
    Arizona
    No man take off the airbobox the connectors are right there. Follow the shift cable down to the trans you'll see what were telling you about
  18. #18 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    Oh God...
    I had both clusters pulled out and I was going to take a picture to post on here...
    They plug into each other.
    Herp derp.
    Bartenders getting up at 8 am to work on their cars...
  19. #19 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    I routed the tranny stuff under the cruise control bracket and plugged it together behind the air box.
    Seems right.
    What clips to each rad support bar?
  20. #20 Re: I need your Engine Bay pics!
    Banned
    Oct 2013
    Moorhead, MN
    Bill,
    I couldn't get into your photobucket.
    Says password is invalid.
  1. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  2. Some new pics of engine n such
    By GTPJOE90 in forum Visual/Body Modifications
    Last Post: 01-23-2009, 12:34 AM
  3. Some new pics of engine n such
    Last Post: 01-16-2009, 04:18 AM
  4. Engine Bay Pics
    By BKA05GT in forum Visual/Body Modifications
    Last Post: 05-27-2008, 12:23 PM
  5. New Engine Bay Pics
    By GTP SE in forum Visual/Body Modifications
    Last Post: 05-21-2008, 08:01 AM
