Thread: seeking professional help, ignition system
Results 1 to 4 of 4
  1. #1 seeking professional help, ignition system
    Sep 2013
    Looking for specifics on ignition system. I just bought myself a 00 gt, I was told it had low fuel pressure and needed new pump. I started going over EVERYTHING,,,, and was able to determine the ICM would trigger 1/4 coil always, the 2/5 coil never, and the 3/6 coil whenever it felt like it. So I replaced the ICM after checking for cam and crank sensor signals and moving coils around to confirm they are good. I have found lots of good info on this site just haven't found this exact issue. Thanks for any suggestions.
  2. #2 Re: seeking professional help, ignition system
    So you have replaced the ICM, but still see no current on the 2/5 coil and sometimes on the 3/6?
    What brand ICM did you buy?
    Are the coils free of cracks/corrosion and are they black (aka stock coils)??
  3. #3 Re: seeking professional help, ignition system
    Sep 2013
    ICM from autozone, duralast I think. The 1/3 coil is black with a yellow insert on bottom at ICM terminals. The other coils are all black. I have checked for spark with a HEI spark tester and also check for trigger signal at ICM.
  4. #4 Re: seeking professional help, ignition system
    Sep 2013
    It turns out,,,, when I pulled the balancer to ck sensor, I found 1 tab for the 18x side of the hall sensor was bent flat instead of sitting at 90 degrees. I bent it back and installed balancer, she started right up !!!!!!!!
  1. professional photoshoot
    By 01 GT in forum Visual/Body Modifications
    Last Post: 07-28-2010, 11:48 AM
  2. Replacing Ignition system 03 GT
    By 03GPGTOWNER in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 07:14 AM
  3. Wiring Diagram, Ignition/security system
    By boogsey in forum General Tech Discussion
    Last Post: 12-25-2008, 11:32 PM
  4. 3800 Ignition System Information
    By SyntheticShield in forum General Tech Discussion
    Last Post: 09-11-2008, 11:32 PM
  5. it was a professional hit!
    By UR LOSN in forum The Rant Forum
    Last Post: 04-14-2008, 01:41 PM
