Thread: Steering Rack Compatibility 05 Base
Results 1 to 4 of 4
  1. #1 Steering Rack Compatibility 05 Base
    Nov 2010
    White Lake, MI
    I have a 2005 base Grand Prix 3.8l N/A with non-variable steering. So my steering rack "does not" have a electronic cord coming from it.
    My question is, would a 06-08 Non-Variable steering rack (with out electronic cord) be compatible with my 05?
    Thanks.
    2005 Pontiac Grand Prix, Base, 3800, N/A
  2. #2 Re: Steering Rack Compatibility 05 Base
    it should work just fine.
    you can look up each years part number and see if they are the same, that will tell you for sure.
  3. #3 Re: Steering Rack Compatibility 05 Base
    Pennsylvania, USA
    Is variable steering an option in itself, separate from Magnasteer? I used to think only Magnasteer included models had variable power steering, but during my one incident of my wheel speed sensor wire getting kinked, I didn't just get the ABS and TCS off messages, I also got variable rate steering disabled. In addition, the wheel was much tighter at lower speeds. Very confusing.
    Like Scottydogs said, part numbers will let you know for sure, either use Rock Auto or gmpartsdirect.
  4. #4 Re: Steering Rack Compatibility 05 Base
    Nov 2010
    White Lake, MI
    I did compare stock number on Rock Auto and see that some are the same for 05 and 06-08.
    To be sure I will call the dealer and see if they can provide any info and to confirm.
  1. GXP steering rack issue
    By NorCalGXP in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2013, 12:58 PM
  2. Steering wheel and after market head unit compatibility question
    By CRASHMAN55 in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2012, 05:23 AM
  3. 98 with leaking steering rack
    By onlysr in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2011, 12:03 AM
  4. steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 11-22-2010, 04:04 PM
  5. steering rack leak
    By 99GPGTP in forum General Tech Discussion
    Last Post: 06-18-2010, 07:37 PM
