Thread: Cat is now bad replacing down pipe....
Results 1 to 20 of 27
  1. #1 Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    I found this down pipe on zz. I have a 2007 Pontiac grandprix base. Do you think it will fit?
    Product Reviews for ZZP Downpipes
  2. #2 Re: Cat is now bad replacing down pipe....
    97-08 can all take the same dp
  3. #3 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    Do you think if I used the 2.5" stainless with cat, that it will set a code? Does anyone have any good/bad experience with zz down pipes that have cats?
  4. #4 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    It's not really a "bad" converter the catalyst is just rattling around. A stock replacement is rediculous compared to the ZZ Performance down pipe.
  5. #5 Re: Cat is now bad replacing down pipe....
    Why not get a catless dp and get the code tuned out?
  6. #6 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    Tuning cost more than what I am willing to pay. Im keeping it stock for now.
  7. #7 Re: Cat is now bad replacing down pipe....
    Aug 2011
    'Merica
    Not if you know someone with DHP of HPT that will erase it for you.
  8. #8 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    lol I wish
  9. #9 Re: Cat is now bad replacing down pipe....
    Aug 2011
    'Merica
    Hit up the Ohio thread. I am sure you can find someone to delete the code out.
  10. #10 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    There is an Ohio thread? Didn't know that....
  11. #11 Re: Cat is now bad replacing down pipe....
    Aug 2011
    'Merica
  12. #12 Re: Cat is now bad replacing down pipe....
    Aug 2011
    'Merica
    there is also a FB page, but I don't do FB so I have never seen it
  13. #13 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    Are you from around my area?
  14. #14 Re: Cat is now bad replacing down pipe....
    Aug 2011
    'Merica
    I'm about 2 hr 30min to the east. Did you know about the meet in Dayton on the 1st of September? You could have your code deleted then if you got the DP installed by then.
    http://www.grandprixforums.net/dayto...1-a-81392.html
  15. #15 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    I had no clue wow im only 20 minutes from Miamisburg and another 10 to Dayton. Where in Dayton do you know?
  16. #16 Re: Cat is now bad replacing down pipe....
    Aug 2011
    'Merica
    linky above
  17. #17 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    lol
  18. #18 Re: Cat is now bad replacing down pipe....
    I'll be at the Dayton meet with my dhp tuner
  19. #19 Re: Cat is now bad replacing down pipe....
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by Spike89 View Post
    Spike89--
    Southern Ohio doesn't have inspections anymore, E-check was one of the most unpopular things around. Save yourself the $40 and get the catless, so long as you don't mind the crispy smell coming out your tailpipe. It bolts in pretty easily as long as you aren't fighting with rusty bolts, IIRC you need a 13 or 14mm socket up front and a 15 in the back, two bolts come off on both ends, stock downpipe comes right off, put some gasket sealant on both ends, bolt the new one in, good to go.
    The front bolts are in an awkward position though, it's a PITA to get out if you're dealing with stuck bolts/don't have a good extension (like I was - a fifteen minute job turned into three hours).
    As far as tuning out the P0140 code that the car -will- throw if you have a catless, just come to the meet - I'm getting mine tuned out on that occasion, too. IIRC dsmuts was charging $20-40 per tune, correct me if I'm wrong?
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  20. #20 Re: Cat is now bad replacing down pipe....
    Nov 2012
    Lebanon, Ohio
    Quote Originally Posted by hensleya1 View Post
    Spike89--
    Yeah I was thinking the same thing hopefully I can get up there to Dayton on the 1st. I'm off that entire week so ill have to show up.
  1. zzp down pipe
    By 2005gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2011, 01:46 PM
  2. I just put a down pipe on my o4 gtp need help ?
    By 98gtp1000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 12:39 AM
  3. Which down pipe should I get?
    By Baron in forum General Tech Discussion
    Last Post: 04-10-2009, 12:14 AM
