Thread: Gaskets Question
Results 1 to 5 of 5
  1. #1 Gaskets Question
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    So I ordered a set of gaskets to do my LIM on my 01 N/A car I got the Fel-Pros I just need to know how and or which of these gaskets to use for the sides of the intake manifold. I'm sure i could probably tell once i take intake of and look at the old gaskets but i figured better to be safe than sorry and know what to do before i start the job. Here is a pic of the gaskets I am talking about
    I know they are used to seal the sides of the intake manifold but I thought there would only be 2 and not 4.
    Also if anyone knows the spec for the torque on the LIM that would be great. I know the UIM is 30in lbs.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Gaskets Question
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    I used the dark blue ones on when I changed the lim last , there is holes in the engine block where you insert those two black tabs. Make sure once those are installed put a dab of RTV at each ends then align the gaskets. The UIM is not 30 ft/lbs its 17 ft/lbs and the lim is 11ft/lbs
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #3 Re: Gaskets Question
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    The blue ones on the left, LIM bolts torqued to 11ft lbs.
  4. #4 Re: Gaskets Question
    Florida
    he said 30 Inch lbs not ft lbs....
  5. #5 Re: Gaskets Question
    This explains the gaskets
    http://www.grandprixforums.net/lim-g...ign-39522.html
    On torque.
    Plastic w/o inserts were 11ft lbs
    Plastic w/metal inserts were 13ft lbs
    I've yet to find a bulletin on the aluminum gaskets, I torque them to 15ft lbs.
  1. Best LIM Gaskets to Use on 3.8 GT
    By indygrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2013, 05:57 PM
  2. SS intercooler install + LIM gaskets question
    By tonglebeak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2012, 07:05 PM
  3. EGR Gaskets?
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 12:44 AM
  4. anoter downpipe question (gaskets)
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 03-20-2009, 02:07 PM
