Thread: Spun rod bearing
Results 1 to 9 of 9
  1. #1 Spun rod bearing
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    So I got a 97 gt with a spun rod bearing.. Only has 150k miles.. I'm pretty sure it's cyclinder 6..
    can I just put a new bearing in there? Or is a new motor needed?
  2. #2 Re: Spun rod bearing
    new motor. If you just replace the bearing it won't last long.
  3. #3 Re: Spun rod bearing
    Apr 2012
    Bancroft. Ontario, Canada
    you could fix it all, but that involves alot of machine work that'll add up really soon... so your best bet is to find another motor... but good luck! 97's are year specific.. Not sure it applies to GT's the same as it did the GTP..
  4. #4 Re: Spun rod bearing
    Quote Originally Posted by Speedy1973 View Post
    97's 4t60e was year only, but any L36/L26 bottem end will swap right in.
  5. #5 Re: Spun rod bearing
    Nothing is year specific to 97 on the motor or trans.. at least not anything that can't be swapped over in under 10 min.
  6. #6 Re: Spun rod bearing
    Nov 2012
    Cincinnati
    So I got the motor and trans out last night.. I did however drop the subframe.. I kind of feel as if it would had been easier taking it out the top? But anyways it's finally out.. I also pulled the harness.. Was overall an easy job... So far haha
    My water proof jack stands
    my plans for right now.. Change tie rods and sway bar.. clean the engine bay up a tad bit.. Clean the yard back up haha
  7. #7 Re: Spun rod bearing
    Nov 2012
    Cincinnati
    So I've came across a sorta local GP GTP for asking price of 700 car has no motor.. But has 151k miles.. Comes with 2 sets of stock rims, torque stars and the ones on the car.. The motor that was in it comes with it but has a smaller zzp pulley so I'm thinking that's why the motor went out..
  8. #8 Re: Spun rod bearing
    That hood is worth over half of what he is asking lol.
  9. #9 Re: Spun rod bearing
    Nov 2012
    Cincinnati
    I realized lol.. He slipped up and mentioned he buys and sells so apparently he doesn't know what he has
  1. spun a bearing??!
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2012, 01:14 PM
  2. So I spun a rod bearing!!!! Advice wanted!!
    By ionroller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2010, 10:16 PM
  3. Spun a bearing
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 12:05 PM
  4. Spun bearing! swap to L26??
    By gixer2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 08:35 AM
