Thread: Rotating / Tilting Engine
Results 1 to 12 of 12
  1. #1 Rotating / Tilting Engine
    Jul 2013
    Upstate New York
    Hey everyone! Been browsing these forums as a guest since I bought my Prix this year, and decided to join today - can't wait to get involved! Anyway...
    I own a 2002 Grand Prix GT (3.8L 3800 Series 2 N/A) and I decided to change the spark plugs, O2 sensors, coils, and wires this week since she's been running a little rough. (I can hear you laughing already). I can get my arm behind the engine but I cannot pull the boots from the plugs (Yes, I tried pliers, twisting, pulling, pulling and twisting but I cannot get enough leverage or space) so I have done a little research here and on google and decided tilting the motor may be my best bet...my question is (since I've heard / read conflicting information that later models with 3800's were not made to be rotated / tilted [seems odd to me]) CAN I SAFELY TILT / ROTATE THIS ENGINE BY SIMPLY UNBOLTING THE DOGBONES / TOP MOUNTS AND USE A RATCHET STRAP TO TILT THE ENGINE? If so, do I strap to the eyelet on the front of the motor (where the dogbone is) or do I use the back lift bracket (or is that just preference)? Do I need to disconnect anything else? I'm assuming shifting to neutral and setting the parking brake applies to automatic transmissions as well? This is my daily at the moment and I don't want to destroy anything. Any help would be greatly appreciated...
  2. #2 Re: Rotating / Tilting Engine
    Simple as that.
    Unbolt dog bones, strap to the engine lift bracket, then hook to somewhere on the core support and it'll come forward to give you a little extra room. And just throw it in Neutral.
    Just dont come so far forward the front exhaust manifold smashes the fans shroud.
  3. #3 Re: Rotating / Tilting Engine
    This is the easiest way to tilt the engine.
    Set the parking brake and put the car in neutral.
    Remove the dog bone mounts.
    Use a ratchet strap to pull the engine forward, you should be able to get it to come forward till the manifolds almost touch the radiator.
  4. #4 Re: Rotating / Tilting Engine
    Jul 2013
    Upstate New York
    Wow! That was quick! Thank you, guys. That was all I needed to know for now - I'll be doing alot more to this thing in the months to come so expect to hear more from me.
  5. #5 Re: Rotating / Tilting Engine
    I would do your lower intake manifold gaskets before you do anything else. But that is just me.
  6. #6 Re: Rotating / Tilting Engine
    Jul 2013
    Upstate New York
    Good man. I was hoping to do them soon along with some HV3 inserts while I'm at it. I'm not leaking any fluid at the moment (crosses fingers) but I would imagine I'll need them soon coming up on 150,000 mi.
  7. #7 Re: Rotating / Tilting Engine
    Jul 2013
    Upstate New York
    Going to do manifold gaskets as you suggested. The stock is plastic correct? Should I go aluminum? ZZP is offering them so I will most likely order those if possible.
  8. #8 Re: Rotating / Tilting Engine
    Yes use aluminum. The plastics ones are stock and are the ones that fail.
    04 Comp G.
  9. #9 Re: Rotating / Tilting Engine
    May 2012
    la mesa, ca.
    I pulled my engine by hand and put one of the dog bone bolts through the hole in the mount. The wires are the hardest part. It takes a lot of twisting and pulling and maybe pliers. Don't forget the dielectric grease in the boots and a little anti seize on the plug threads. It will make it easier next time. AC delco iridium plugs are best
  10. #10 Re: Rotating / Tilting Engine
    Quote Originally Posted by divisor View Post
    Parts stores carry them, screw buying through ZZP for some gaskets.
  11. #11 Re: Rotating / Tilting Engine
    Jul 2013
    Upstate New York
    Fair enough.
  12. #12 Re: Rotating / Tilting Engine
    Jul 2013
    Upstate New York
    Hate to keep this thread alive for so long, but a quick question about blocking the coolant ports in the LIM. Is it still a good idea to plug the ports in the LIM if I am replacing my UIM with the dorman 615-180 (since it apparently has the redesigned EGR area?) or is it just unnecessary in this case (replacing the UIM)? I'll also be doing VC gaskets...any other ideas on what to do while I'm in there?
  1. tilting a 3800
    By 04silverprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2013, 03:46 PM
  2. Rotating assembly repair without removing engine?
    By Rico in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2011, 12:01 PM
  3. Wondering if rotating tires could help with flat spots
    By M0nkeyp00p in forum Tires & Wheels
    Last Post: 03-09-2009, 11:44 PM
  4. Tilting 9007's!
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-25-2008, 07:59 AM
