Thread: Next Upgrade?
Results 1 to 20 of 33
  1. #1 Next Upgrade?
    Chicago, IL
    So I was wondering if you guys had any opinions on what I should upgrade next? I have a k&n air intake, msd ign. coils, and slp head to tail. Any ideas?
  2. #2 Re: Next Upgrade?
    Banned
    Wichita Falls, Texas
    Sell the K&N intake and buy a Thrasher, Wizaired, or build a Fender Well Intake.
  3. #3 Re: Next Upgrade?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Ya the K&N intake is just about the worst CAI out there, hate to break it to ya.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  4. #4 Re: Next Upgrade?
    Chicago, IL
    I didn't want to admit it at first but the K&N intake is horrible. Its expensive too!!
  5. #5 Re: Next Upgrade?
    Jul 2008
    Dekalb, IL
    Ya I've seen several people post up scans with over 100* intake temps on around 60* days and both of them had the K&N CAI.
  6. #6 Re: Next Upgrade?
    Chicago, IL
    I think I will switch it out and get the Wizaired CAI, then a new throttle body, then probably a pulley or two. The 2004+ GP's have the MAF sensor separate from the throttle body right?
  7. #7 Re: Next Upgrade?
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by 04gpking85 View Post
    What your mod list? I wouldn't start dropping pulley sizes until you have some decent exhaust mods, especially on a L32.
  8. #8 Re: Next Upgrade?
    Chicago, IL
    My mod is K&N air intake, msd ignition coils, slp head to tail(headers, downpipe, high flo cat, cat back exhaust) and overkill pcm.
  9. #9 Re: Next Upgrade?
    Jul 2008
    Dekalb, IL
    Looks like your good on exhaust mods, definitely look into getting a different intake and dropping pulley sizes.
  10. #10 Re: Next Upgrade?
    Chicago, IL
    Yeah I'm not sure what pulleys to start with, I'll have to do some research
  11. #11 Re: Next Upgrade?
    As I was reading this...I got kinda lost...isn't this the section for LQ1 motors...like the DOHC ones...not the Supercharged 3800? Just thinkin' this might be in the wrong place idk...Last time I checked though that 3.4 Dual Cam never had the option to drop a pulley size LOL
  12. #12 Re: Next Upgrade?
    Chicago, IL
    Actually mine is the 3.8L Non supercharged, I have posted in the wrong section though oops.
  13. #13 Re: Next Upgrade?
    Jul 2008
    Dekalb, IL
    Oh your not supercharged? Then the whole dropping pulley sizes really doesn't apply to you lol. Personally if I were you I'd consider doing a top swap for your next mod, you would really benefit from it seeing as you have higher compression from the L26 and you already have a good amount of supporting mods for a slightly smaller pulley.
  14. #14 Re: Next Upgrade?
    Barksdale AFB, LA
    Can't drop SC pulley sizes on an engine with no SC.
    2009 Subaru Impreza WRX STI
  15. #15 Re: Next Upgrade?
    Chicago, IL
    What is a top swap? Sorry but I don't know the terminology yet. So I was looking at putting in a water pump pulley and an under drive pulley from ZZP, good idea? Also why is the wizaired cai better then the k&n cai?
  16. #16 Re: Next Upgrade?
    Barksdale AFB, LA
    Not sure why this isn't stickied yet....
    http://www.grandprixforums.net/f17/t...lots-7763.html
  17. #17 Re: Next Upgrade?
    Jul 2008
    Dekalb, IL
    A top swap is basically the addition of a supercharger, go to that link that Sabrewings posted and it should explain everything. The Wizaired CAI is better cause it actually draws in cold air as opposed to the K&N CAI which, contradictory to it's name, doesn't.
  18. #18 Re: Next Upgrade?
    Chicago, IL
    So would getting aftermarket pulleys be a good idea?
  19. #19 Re: Next Upgrade?
    Jul 2008
    Germantown, Maryland
    yea you didnt need the coils either, the stock ones are just as good if not better
  20. #20 Re: Next Upgrade?
    Jul 2008
    Dekalb, IL
    They really aren't going to do much for you, like at all. If you don't plan on going SC then maybe look into getting a HV3 from ZZP.
  1. need upgrade help
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 01-28-2010, 11:33 AM
  2. Here I go again, suspension upgrade
    By David99GTP in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2008, 02:08 PM
  3. Computer Upgrade!!!
    By offroadfury6 in forum General Tech Discussion
    Last Post: 08-14-2008, 01:14 PM
  4. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
  5. First upgrade...
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-13-2008, 11:13 AM
