Thread: a few problems and now im stuck....
Results 1 to 16 of 16
  1. #1 a few problems and now im stuck....
    Sep 2012
    fort Wayne, in
    ok so i bought the car about a year ago and it was driving horrible!! i found out that two coils and the icm were done. so i went to my local pick-a-part and bam, fixed it...kind of. the idle started getting kind of ruff as in going from 800-1300 and kinda chugging. so i started snooping around, and got it scanned and found out the o2 sensors were bad so i was like dang. so i went out and got a new front o2 sensor because i was told the second one only served a purpose of telling me if the cat was clogged and i was told that the cat was not clogged and it was good. so once i did all that the car started not acerlating right so i changed the spark plugs to copper ac delco. when i did that the car started doing great. and now when i accerlate the car seems like it sputters/pauses then surges i guess you could say. if i gradually go wot off the line it studders and kinda shakes then gets up and goes. im thinking maybe the injectors but i dont wanna spend 85 bucks a peice just to find out that wasnt it. any ideas or anything would help. thanks in advance
  2. #2 Re: a few problems and now im stuck....
    Then let's not blame something that typically doesn't fail.
    What year is this car?
  3. #3 Re: a few problems and now im stuck....
    Sep 2012
    fort Wayne, in
    the car has 141000 on it and its a 99. i thought injectors fail all the time?
  4. #4 Re: a few problems and now im stuck....
    I dunno guy.. I've had a few 3.8's and well into 200K miles.. never had an injector fail yet. I've seen one or two fail here or there on other folks cars..but not all 6 at one time. How about this.. I'll give you some questions and answers.. then before we spend any money... likely we'll have it fixed. Sound like a deal?
    How many miles since you put the plugs in?
    You are correct, in 99 the rear O2 doesn't affect fueling.
  5. #5 Re: a few problems and now im stuck....
    Sep 2012
    fort Wayne, in
    id say probably 2 or 3 hundred miles since ive put the plugs in
  6. #6 Re: a few problems and now im stuck....
    Sep 2012
    fort Wayne, in
    i forgot to say it i havnt noticed it doing in corners but ive noticed only in a straight line
  7. #7 Re: a few problems and now im stuck....
    Any codes?
  8. #8 Re: a few problems and now im stuck....
    Jun 2013
    I had similar issues with my gt and i ended up replacing my cat(i knew it was clogged), both 02 sensors, all new plugs, and wires, and coil pack for 1,4. I'm not sure if you included wires when you replaced your plugs, but maybe look into that too if you haven't, i got mine for $23. Also make sure you don't have a cracked plug. When i replaced all of my plugs with new ones, I didn't realize that I put a new, cracked, plug in. I am by no means an expert with these cars, but i would look at replacing wires if you haven't already, and look at all your plugs and make sure they are still good.
  9. #9 Re: a few problems and now im stuck....
    Pennsylvania, USA
    It would be worthwhile to try cleaning the MAF sensor as well, cheap and easy.
  10. #10 Re: a few problems and now im stuck....
    Sep 2012
    fort Wayne, in
    i havnt got the car scanned just yet but how often do wires need changed? probably would have been a good idea to change those when i changed the sparkies. would a misfire come up on a scanner from like autozone or anything? last time i went and got scanned from them they barely knew how to use the dang thing! i havnt been able to check the maf just yet just because i havent gotten the right wrench with the safety knob in it yet. you can get those at autozone pretty cheap? cause walmart didnt have it
  11. #11 Re: a few problems and now im stuck....
    I think you said the problem. Plug wires should definately have been changed at the same time as the plugs..
  12. #12 Re: a few problems and now im stuck....
    Sep 2012
    fort Wayne, in
    So i pulled all sparkies out and checked for cracks and nothing but the middle one was a little more discolored than the rest with a reddish color on the tip of the metal part and on the porcelain but other than that looked good. Looked at the inside of the wires and looked alittle rusty and one of the boots was split alittle but still seated very well on the sparkie
  13. #13 Re: a few problems and now im stuck....
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Just because they are seated well on the plug doesn't mean they're making a good connection. Corrosion on the wires will lead to poor connections.
  14. #14 Re: a few problems and now im stuck....
    Store brand wires are cheap enough pick up a set or spend $40 on Ac Delcos.
    04 Comp G.
  15. #15 Re: a few problems and now im stuck....
    Sep 2012
    fort Wayne, in
    Ok so i ordered wires from Rock auto ac Delco's for 30 bucks shipped. But today I was going up a sight hill of an overpass and the car studdered so I'm hopeing tHis works
  16. #16 Re: a few problems and now im stuck....
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Don't forget the di-electric grease on both ends of the wires when you install them....
    If you suspect injectors, you can have them cleaned and rebuilt with new pintles and internal sock filters. I sent mine to Mr Injector in Idaho for $16 each plus shipping. He will turn them around same day but it's 2 days shipping each way.
  1. Replies: 6
    Last Post: 11-01-2012, 11:35 PM
  2. Car stuck in park, key isn't stuck though
    By capitalcrew in forum General Tech Discussion
    Last Post: 05-03-2012, 10:28 PM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. 04+ HUD is stuck...
    By PonchoDvr4Lfe in forum General Tech Discussion
    Last Post: 02-22-2012, 01:55 PM
  5. Wiper Problems. Stay stuck up.
    By Rather B Blown in forum General Tech Discussion
    Last Post: 03-16-2009, 01:53 PM
