Thread: How Do I Make a 07 Grand Prix Sedan Faster?
Results 1 to 19 of 19
  1. #1 How Do I Make a 07 Grand Prix Sedan Faster?
    SE Level Member GPRedDevil's Avatar
    Nov 2008
    Warren
    I have a 2007 Grand Prix Sedan Base Model and Its has Series III 3.8L 200hp Engine, Its pretty Quick but i Want it to be FAST Any Ideas of how i Can Achieve this?
    Get.It.IN
  2. #2 Re: How Do I Make a 07 Grand Prix Sedan Faster?
  3. #3 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Nov 2008
    Warren
    Turbo, What Kind? Why not a Supercharger?
    Get.It.IN
  4. #4 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    a turbo is the big power maker for these cars. at the same boost level they make a ton more power.
    look into the z7 kit at ZZPerformance
  5. #5 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    GT Level Member Injun #4's Avatar
    Anderson, SC
    Quote Originally Posted by GPRedDevil View Post
    Because a supercharger is belt driven which requires HP generated by the motor to drive the pulley, and a turbo is using recycled exhaust which does not cause parasitic HP drain on the motor.
    A supercharger, however, makes instant horsepower as opposed to a turbo which usually has a bit of a lag (size/type of turbo and your specific set-up will determine how much lag).
    Instant power: supercharger > turbo
    Total power: turbo > supercharger
    At least that's the way it's always been described to me...I'm sure somebody will correct me if I'm wrong though.
    This one has a V8.
    Why not just make a V6 faster?
    This one has a V8.
  6. #6 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Donating Users
    W-S, NC
    Quote Originally Posted by Injun #4 View Post
    ^ X2. A good turbo setup will not have much lag and spool quickly with max. output. This is why you hear about people running a t3/t4 hybrids in smaller displacment engines. Smaller turbine (T3) in a larger housing (T4).
  7. #7 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Barksdale AFB, LA
    There is still parasitic loss with a turbo (the power to compress the air has to come from somewhere), but a turbo is more efficient so it creates less.
    2009 Subaru Impreza WRX STI
  8. #8 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Oklahoma
    Moved the correct section. Please familiarize yourself with the following:
    http://www.grandprixforums.net/f14/a...read-6828.html
    Post #7
  9. #9 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    May 2008
    staten island,NY
    do any of the vendors have 07 pcms out yet? turbo build is easily 10grand if not more. i feel thats a waste of money. youy can do bolt ons and have a quick car, or get a LSX car for FAST
  10. #10 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    SE Level Member $03gp/gt$'s Avatar
    Feb 2008
    Chillicothe/Peoria IL
    What all is needed to convert my 03 gt to be supercharged? I have found a good deal on some superchargers... What all is needed to be done and changed to install the supercharger. I know the gtp's come stock with 270 hp. and the gt's come stock with 200 hp. I want to push at least 325 hp for now until I decide I want it faster...Please drop me some pms and let me know.
    Thanks
    Josh
  11. #11 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    May 2008
    Winnipeg, MB
    Quote Originally Posted by $03gp/gt$ View Post
    Thanks
    Josh
    $$$ and time is not worth it to S/C a NA motor IMO
    gtp's have 240HP
    for 325HP you need a turbo
    2007 Pontiac Grand Prix
  12. #12 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Barksdale AFB, LA
    Thanks
    Josh
    97-03 GTPs had 240HP. 04+ Supercharged GPs had 270HP.
    To do a real conversion of your non-supercharged block, you need to replace everything from the heads up. Otherwise you can use ZZP's SS M90 kit and the required parts they specify. This is nothing for the light hearted or inexperienced to try and do. You'll need access to someone who can tune, access to lots of tools, preferably experience working with engines in this way, etc.
  13. #13 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Feb 2008
    oh i was told different well instead of paying big money on all that what is the best way to get some more hp...I got a K&N Air Filter in the stock box and Flomaster Exhaust all bolt on with the cat still on it...I want to get some more power please help me...Im new to the 3800 stuff...
  14. #14 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Barksdale AFB, LA
    Without a turbo or supercharger, you're probably going to max in the 240 crank HP range with your 3800. The record 3800 has about 300 crank HP, but that has tons of work and was built just to set the record.
    If you want some decent gains to make it a little more spirited to drive, you'd probably like how mine is now. CAI, DP, Plog, HVTB, and some good tuning.
  15. #15 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Feb 2008
    Man im lost with the CAI, Plog, HVTB i have no clue what that stuff means lol....Im trying to ask so I can learn some stuff about it... Should I Build my own FWI would that give me some hp and better gas mileage? Also remember I do have Flomaster Exhaust.. What can I do to get it to sound a lil better and get better air/fuel mixture to get a lil more hp outta of it also? Im tryin to find all the little tips just to get started on having a lil better performing car..
  16. #16 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Barksdale AFB, LA
    Here's my CAI (cold air intake):
    ZZ Performance
    Can you build one? Sure. It probably won't be as good at insulating the intake charge, and probably won't look as good if you're into showing your car. But, it'll function.
    Plog:
    ZZ Performance
    DP (downpipe):
    ZZ Performance
    HVTB:
    ZZ Performance
    With all this you're going to want some tuning to not go lean when you floor it. Overkill Motorsports or Intense racing would be good places to get it.
    Ditch the flowmasters. Get something by Magnaflow.
    Air/fuel mixture is controlled by the PCM. Changing that requires tuning.
    Catbacks don't really make HP until you're really modded. If you want to get one, you're only doing it for looks and sound.
  17. #17 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Feb 2008
    I was thinking of goin with Magnaflow. I got my exhaust for $50 from one of my friends just so I wouldnt be running stock pipes you know. I have been reading bout Overkill pcm im really thinking of goin that route instead of zzp.
  18. #18 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    Jersey
    Woot Woot Overkill!
    16' wrx sti- stock
  19. #19 Re: How Do I Make a 07 Grand Prix Sedan Faster?
    SE Level Member WillOverkill's Avatar
    Feb 2008
    Unfortunately noone offers 07-08 PCM tuning currently, including myself We're on the list to beta test 06+ specific software but its been more than a year with no signs of progress on it from our suppliers.
    We can offer you an 05 PCM for your vehicle but the fuel gauge will read backwards!
    Intake, downpipe and highflow cat are your best place to start for now.
    Get Your 3800 Overkilled @ http://www.getoverkilled.ca
  1. Those anybody know if they make projector headlights for grand prix 2004?
    By Whitehispanic in forum Visual/Body Modifications
    Last Post: 01-30-2010, 12:44 AM
  2. make it faster!!!
    By 52 picup in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 10:28 PM
