Thread: New ac resistor, fan not coming off when car is off...
Results 1 to 2 of 2
  1. #1 New ac resistor, fan not coming off when car is off...
    Jun 2013
    Dallas
    I recently replaced my blowor motor resistor and now when i cut the car off the fans dont come off and drains my battery...anyone know of this issue and how to fix?
  2. #2 Re: New ac resistor, fan not coming off when car is off...
    Florida
    the blower motor resistor has nothing to do with your engine fans coming on or off. are you sure your fans came on after turning off the car before? a lot of these cars do not normally have the fans set like this. only after tuning or pcm swap will the fans kick on after shutdown. if the battery is draining, i would start looking for something shorting and causing the draw. if you think it is fan related pull the fuse and see. since you just replaced the blower relay i would look in that area first. see if anything was crossed. hope this helps.
  1. Bypass VAT with resistor?
    By Paranoid in forum Audio, Security & Visual Electronics
    Last Post: 07-25-2012, 01:47 AM
  2. blower resistor
    By indyal in forum General Tech Discussion
    Last Post: 01-09-2011, 07:57 PM
  3. fan resistor
    By jmanners in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2009, 10:36 AM
  4. LED resistor help
    By BluFlameGTP in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 01:26 AM
