Thread: Rough Idle - Smooth riding - PCV replacement?
Results 1 to 7 of 7
  1. #1 Rough Idle - Smooth riding - PCV replacement?
    Aug 2012
    United States
    Hi Guys,
    My car is running great, but idling very rough. Today the service engine light came on. Can someone tell how to change the PCV valve? I found a nice slide show for a supercharged engine, but the location isn't the same on mine.
    Thanks!
  2. #2 Re: Rough Idle - Smooth riding - PCV replacement?
    Pull the 2 10mm bolts off of the pcv plate and remove that and pull the pcv valve out and put your new one in making sure all orings and springs are in place.
  3. #3 Re: Rough Idle - Smooth riding - PCV replacement?
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
  4. #4 Re: Rough Idle - Smooth riding - PCV replacement?
    Pennsylvania
    I goggled "grand prix pcv" and this was the first image. Way easier than describing it.
    On the other hand, I really super-doubt that a bad PCV valve is causing your issues. Take it to parts store and get it scanned. Chances are something fancy like the MAF sensor is borked.
  5. #5 Re: Rough Idle - Smooth riding - PCV replacement?
    Aug 2012
    United States
    Thanks for all the info guys...and you were right slowna06 it wasn't the pcv. Then engine light went out and it seems to be running better I have a feeling the spark plug wires were arching. Running right to Advanced Auto next time the light comes on.
  6. #6 Re: Rough Idle - Smooth riding - PCV replacement?
    Jun 2013
    Middleville
    Here is another thing to think of maybe the EGR valve was stuck open that'll cause no vacuum at idle which would cause a rough idle just my tow cents worth
  7. #7 Re: Rough Idle - Smooth riding - PCV replacement?
    Pennsylvania
    EGR stuck open will be a huge vacuum leak... it'll sound like it's cammed... but it'll run fine. Check maf% with a scanner.
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. GTP Rough Idle
    By jaredhagen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 01:32 PM
  3. rough idle after engine replacement
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 07:55 PM
  4. Rough when cold; smooth when warm...???
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 07:34 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
